alarm with fog lights..need help
Old Oct 6, 2009 | 08:08 PM
Lovin_My_E.G[G]'s Avatar
Default alarm with fog lights..need help
my buddy has a 95..i think, civic coupe and he has the jdm fogs and he also has an alarm and they both have to take the same spot in the fuse box...but he obviously wants to run both..what do i do? where else can i plug it in?
Old Oct 6, 2009 | 09:05 PM
wicked_gk's Avatar
Default Re: alarm with fog lights..need help
what do u mean they have to take the same fuse place? is he running them to the headlight fuse? you really shouldnt be adding more of a load to an existing circuit it will cause more resistance. the alarm wouldnt hurt much but the fogs will put larger load.
the right way to do this is to run a 10-12 gauge wire from the battery to a distributor terminal. connect the fogs to the terminal with a switch and whatever other aftermarket parts u might add.
Old Oct 7, 2009 | 08:27 AM
well the fogs work fine but he has an alarm too and its suppose to plug into the same place as the fogs do (underneath the steering wheel) where else can i plug the alarm into?
mish__
Audio / Security / Video
May 18, 2010 11:20 PM
1BADEGDC2
Dec 30, 2008 04:29 PM
Balltongue0077
Dec 15, 2008 09:37 PM
jiggatone
Lighting
Jan 27, 2008 07:47 AM
frog169
Sep 16, 2006 11:19 PM
