alarm with fog lights..need help
my buddy has a 95..i think, civic coupe and he has the jdm fogs and he also has an alarm and they both have to take the same spot in the fuse box...but he obviously wants to run both..what do i do? where else can i plug it in?
Re: alarm with fog lights..need help
what do u mean they have to take the same fuse place? is he running them to the headlight fuse? you really shouldnt be adding more of a load to an existing circuit it will cause more resistance. the alarm wouldnt hurt much but the fogs will put larger load.
the right way to do this is to run a 10-12 gauge wire from the battery to a distributor terminal. connect the fogs to the terminal with a switch and whatever other aftermarket parts u might add.
well the fogs work fine but he has an alarm too and its suppose to plug into the same place as the fogs do (underneath the steering wheel) where else can i plug the alarm into?
