car probelms look got a vid
Old Oct 5, 2009 | 07:28 PM
bryce warburton's Avatar
Default car probelms look got a vid
http://www.youtube.com/watch?v=XKctkc9kTPk
my car wont drive far then dies and it does this just did an engine swap had some loose grounds fixed that and it just acts up
Old Oct 5, 2009 | 07:35 PM
TheMuffinMan's Avatar
He knows where you live!
Default Re: car probelms look got a vid
Engine swap to what and from what?
What did you change/modify?
Old Oct 5, 2009 | 07:52 PM
i just changed the motor out it was bad put same engine in
Old Oct 5, 2009 | 07:55 PM
Did you reuse the ECU or have a new one?
I don't know of any one part that would cause issues like that except for wiring or ECU. Especially if the RPM's aren't actually reflecting the motor revving up.
Old Oct 5, 2009 | 08:00 PM
Go_Race_Your_Self's Avatar
Two Piece
Hmmmm, does it do that at operating temp.?
Old Oct 6, 2009 | 07:24 AM
yea idk we reused the same ecu and i was thinking it was the fuel pump but now it does this
Old Oct 6, 2009 | 07:32 AM
Is the car actually revving like that or is it just the cluster?
Old Oct 6, 2009 | 08:37 AM
no its actually revving like that i just had to use some starting fluid to get it to go
Old Oct 6, 2009 | 05:54 PM
problem found drove it today no problems it was the ground on the driver side on the intake i guess it went to alot fuel pump and cluster ground etc
ef'dup
May 18, 2012 05:12 PM
Cpk8287
Jun 14, 2011 07:35 PM
DarkBB4
Sep 14, 2007 01:30 PM
Garage786
Mar 11, 2007 03:00 AM
