clear coating polished surfaces? rattle can + si wheels
Old Oct 5, 2009 | 04:08 PM
JDMB20TDA's Avatar
Default clear coating polished surfaces? rattle can + si wheels
picked up a set of worn si wheels, polished them.
They are going to be my winter wheels, Unfortunately for some this is no problem.
I live in chicago where salt eats cars.
I picked up a can of rustoleum clear wheel paint, in hopes of protecting the finish over the winter, wasnt to confident it would hang onto the polished surface real well so I figured Id ask.
or should I just polish and wax?
thanks
Old Oct 5, 2009 | 04:24 PM
TunerN00b's Avatar
Default Re: clear coating polished surfaces? rattle can + si wheels
I doubt it will stick very well. The wheels originally had a machined face, with the machined lines available to help the clear stick.
Call places that offer powder coating services, as some of them have clear powder coating.
Otherwise, like all polished wheels, its polish and wax, and repeat regularly.
Old Oct 5, 2009 | 04:27 PM
JDMB20TDA's Avatar
yea just worried about pitting and corrosion over winter.
Old Oct 5, 2009 | 05:12 PM
bakertime's Avatar
I've been curious about this for a while too...
Old Oct 5, 2009 | 06:22 PM
02cavquest's Avatar
Try it out. Keep us updated. I'm interesed in the outcome.
Old Oct 5, 2009 | 06:30 PM
JDMB20TDA's Avatar
Originally Posted by 02cavquest
Try it out.
well Id rather learn from others than risk having to completely redo them next season.
anyone have any experience with this?
Old Oct 5, 2009 | 06:50 PM
bakertime's Avatar
I think you're right that it won't stick if polished, but perhaps there is a grit that won't show scratches after being covered with clear, but will still have good adhesion. What grit that is...well I have no idea. Maybe around 600 or so.
Old Oct 6, 2009 | 08:05 AM
JDMB20TDA's Avatar
nah Im at 2000+ at this point.
even wet 2000 grit without a good buff shows scratches.
May just rock em without clear for fall.
Old Oct 6, 2009 | 11:56 AM
B and B's Avatar
Loved
Community Favorite
You need to do something to the scalloped areas anyway...flaking
Old Oct 6, 2009 | 12:24 PM
bakertime's Avatar
Yeah, 2000 grit WITHOUT clear shows fine scratches, but you gotta figure the clear will fill a lot of that. There has got to be a certain grit that still allows the clear to 'bite' on to the surface, but will also fill scratches. That's where I was suggesting 600. If you could find an extra wheel, that would be good to play around with. You could sand sections with different grits, label them and then shoot the whole wheel with clear to see what it looks like.
Old Oct 6, 2009 | 02:07 PM
©twitch©'s Avatar
clear powder coat is the only thing thats gonna stick
Old Oct 6, 2009 | 02:15 PM
dreamreaperx's Avatar
well i know that when doing a spot job on a car, they usually sand the surrounding areas with 1000 grit and the clear sticks fine...not sure if any higher than that will work
Old Oct 6, 2009 | 07:49 PM
JDMB20TDA's Avatar
nah thats a picture while I was wetsanding those areas prior to painting them.
they're are all good now.
but I may just have no choice,
-powder coat, more than I paid for the wheels...
-zoop seal, polished aluminum sealer also expensive and must be applied regularly
-Polish and wax regularly.
and Im going with # 3, Id hate to use the clear rattle can on the polished surfaces have it peel then have to strip it all again. Taping off all the pie cuts was a pain.
not to mention they are just winter wheels, the salt couldnt possibly eat the aluminum to the point a good polish wouldnt fix.
thanks guys, if anyone has any experience with just a carnuba wax through a harsh winter let me know if its going to work.
Old Oct 6, 2009 | 10:25 PM
DynastyRacer22's Avatar
try opti-seal after u polish and wax http://www.youtube.com/watch?v=Xj1mNrc6IIc
im pretty sure these will work with polished wheels
Old Oct 7, 2009 | 11:59 AM
JDMB20TDA's Avatar
picked up some meguires cleaner wax, Looks like a cleaner wax is whats recommended and will help polish in between coats.
Old Oct 7, 2009 | 05:42 PM
JDMB20TDA's Avatar
Old Oct 8, 2009 | 10:35 AM
bakertime's Avatar
Looks nice!
Old Oct 8, 2009 | 11:38 AM
SykVSyx's Avatar
Turned out great.
Gotta love road salt.............
Old Oct 8, 2009 | 02:05 PM
JDMB20TDA's Avatar
hate winter
MattH
Jun 5, 2016 12:13 PM
KeithsDAteg
Nov 23, 2011 05:55 PM
cbstd
Jun 4, 2008 08:09 AM
Cosworth
Oct 5, 2001 08:03 PM
