CEL light wont read codes
Old Oct 4, 2009 | 07:23 AM
boostd ls's Avatar
Default CEL light wont read codes
i have a 92 civic with 94 gsr swap the checkengine light came on and car wont rev past 4k rpms now i tried to scan codes by putting a jumper wire in the connector and turning the key on but the CEL just stays on and doesnot blink any ideas or help would be greatly appreciated thanks
Old Oct 4, 2009 | 08:26 AM
Former User's Avatar
Default Re: CEL light wont read codes
You have CEL code 0, which indicates an ECU problem. In your case, there is a short or open in the brown wire running between the 2P service connector and ECU or the ECU is bad.
Old Oct 4, 2009 | 09:29 AM
boostd ls's Avatar
the ecu is a p28 with hondata s100 i unplugged it and put in the stock p72 no probs then put the p28 back in and no more check engine light weird looks like someone had a vafc in the car at one time would a loose connection cause this
Old Oct 4, 2009 | 09:45 AM
Yeah, just sounds like the problem was a loose ECU connector.
4DALOOKS92
Apr 16, 2016 07:46 AM
92DAB16A
Sep 14, 2012 07:14 PM
honda_aus87
Mar 26, 2011 08:01 PM
RexB16
Jun 3, 2005 10:34 AM
RexB16
Jun 3, 2005 10:33 AM
