anyone know much about EG CLUSTERS!?
Old Oct 4, 2009 | 05:18 AM
TweedZ's Avatar
Default anyone know much about EG CLUSTERS!?
i have an eg ex/si cluster, speedo and odo don't work. i think the needle died.
i tried 3 diff vss sensors that i KNOW work and none of them fixed it, i checked voltages at vss as well so i think needle is just dead.
how difficult is this to replace and where can i get a new needle or motor or whatever it is i will need?
Old Oct 4, 2009 | 05:51 AM
TweedZ's Avatar
Default Re: anyone know much about EG CLUSTERS!?
would i be able to just take another cluster and swap the speedos with circuit board?
Old Oct 4, 2009 | 06:22 AM
rotasol's Avatar
You changed the sensors, but did you take the shaft and gear out and inspect them?
As for swapping speedos from clusters, it should work, as long as they're the same speedo.
Old Oct 4, 2009 | 07:18 AM
TweedZ's Avatar
as in the little gear that goes spins inside both the tranny and the sensor? if so yes i swapped that as well.
so same speedo as in they both need to come from an ex/si cluster or could i take a speedo out of a dx cluster that had no tach and use that speedo?
not sure if they would be programmed the same
Old Oct 4, 2009 | 09:58 AM
rotasol's Avatar
As long as the speedo stops at the same speed (as in they both top out at 220KM/H) you should be ok I think.
With it being electronic, I doubt the tach has anything to do with it. I'm basing this totally on common sense, as I haven't done it before.
Old Oct 4, 2009 | 10:49 AM
roycivic92's Avatar
where u at . i have a dx cluster laying around some where we can try it.
Old Oct 5, 2009 | 05:37 AM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Any 92-95 speedometer should work, from any cluster.
Old Oct 5, 2009 | 06:08 AM
Import_spoon's Avatar
Yes you can switch just the speedo from any 92-95 Civic. Remember seeing a write of swapping out the speedo for correct mileage. That will help you. Just go search for it.
Old Dec 16, 2009 | 12:17 PM
ben98gs's Avatar
Does this just pull straight out? I thought the shaft that stuck up was small and pulled out without pulling the full shaft/gear out? Like in the picture below:
Old Dec 16, 2009 | 04:37 PM
Pat_S's Avatar
Out of curiosity, where were you able to dig and find this diagram?
Old Dec 16, 2009 | 04:42 PM
thecruzs2007@yahoo.com's Avatar
i have the same problem..i swapped out my vss to a new one and it still doesnt read..ima try a new cluster..but if you get any 92-95 cluster they should plug and play...
Old Dec 16, 2009 | 11:46 PM
snake_eyes's Avatar
check the connector a lot of times ull find corrosion in the terminals. check it and if its bad just wire a new vss harness in. i know 3 other people that had that problem and it was the harness.
Old Dec 17, 2009 | 03:56 AM
ben98gs's Avatar
Thank RonJ@HT for it. He posted it in another topic. Someone also posted a picture of the whole VSS assembly (including the gear) out of the transmission, but I do not think my tranmission has a spot where it can pull out, I believe the actual sensor just bolts to the case of the transmission and the gear is inside the case. That is why I was asking, how are people checking this gear/pulling out the shaft? I would really like to get this working.
Old Dec 17, 2009 | 03:57 AM
ben98gs's Avatar
Know of anywhere I can buy the harness brand new? I know I can go to a junkyard and splice one off, but would rather just get a new one if possible.
Old Dec 17, 2009 | 02:52 PM
B16aEk4drbeater's Avatar
I suggest swapping the cluster first, its a very common problem... if the speedo is the only thing that dont work then you can swap it out from a Dx model also,, I did it a million times.
vspec128
Jun 10, 2011 06:38 PM
Freeltec
Aug 20, 2009 07:54 PM
AnDy327
Jun 22, 2008 02:15 PM
kyorishin
Mar 1, 2008 07:01 PM
pr_tony_montana
Nov 10, 2004 07:24 AM
