CRX B16 swap, No pump prime
Old Oct 3, 2009 | 01:57 PM
diamondstarsforever's Avatar
Default CRX B16 swap, No pump prime
Car worked 100% when it went on the jack stands. I pulled the d out and but a b16a in with a hasport subharness now the fuel pump isn't priming. With the b16 ecu there is no prime or click at all from the main relay it's also not throwing any codes. With the d16 the main relay is just constantly clicking now. Could the b16 ecu be bad? I've double checked my repins on the harness to make sure I didn't repin the wrong ones.
Old Oct 3, 2009 | 02:46 PM
Default Re: CRX B16 swap, No pump prime
Valve cover and tranny are both grounded. Maybe a bad ECU?
Old Oct 3, 2009 | 02:52 PM
Bunger's Avatar
Battery is good? Lights coming on? What happens when you crank?
Old Oct 3, 2009 | 02:55 PM
Battery is good, Radio comes on, Lights come on. When I crank it, It just turn and turns.
Old Oct 3, 2009 | 04:05 PM
abnaasefmb's Avatar
check all your fuses
Old Oct 3, 2009 | 05:16 PM
All fuses are good.
Old Oct 3, 2009 | 06:10 PM
Main relay just tested good.
Old Oct 4, 2009 | 10:22 AM
After much googling I came to a thread on CRXCommunity that talked about ecu issues and trouble shooting them. Long story short I had missed the ground on the engine harness, It looks just like the one that came with the hasport harness so I just combined the two in my mind I guess. Thanks to those we tried to help me.
eatxsleepxjdmx
11
Aug 14, 2012 06:12 PM
BoostinTEG
Sep 14, 2011 07:07 AM
Dipset Racing
Feb 19, 2010 03:39 PM
hisnibs
60
Oct 14, 2009 09:36 AM
smokincrxwannabe
Mar 14, 2008 06:24 PM
