alignment of the intake cam and distributor?
Old Aug 28, 2002 | 03:01 PM
takeheed's Avatar
Default alignment of the intake cam and distributor?
1)should the female part of the intake cam and the male part of the distributor be perfectly flush when put back together?cause i cant get them to do that
2)also should the key grooves for the cam gears on the shafts be facing straight up and downwhen put back in or are they slightly facing eachother?
thanks in advance + + =
Old Aug 28, 2002 | 04:28 PM
Hondasaurs's Avatar
Default Re: alignment of the intake cam and distributor? (adamjoey)
I assume your working on a DOHC engine, can you be a little more specific and provide what engine you are working on?
Old Aug 28, 2002 | 07:34 PM
takeheed's Avatar
Default Re: alignment of the intake cam and distributor? (ZC_CRX)
1st gen b16a. when you install the cams first you set the #1 piston at TDC then you position the cams so there are no open valves ,right? now,there is two slots on the end of the intake cam,and on the distributor there is two teeth that fit in those slots,correct? those teeth should fit in those slot perfectly ,no?there is were my problem is,the cams are seated perfectly and it appears by looking at those slots that it needs another 3/16 to be flush.does that make any sense
Old Aug 28, 2002 | 08:34 PM
USDM 4G VTEC's Avatar
before u attemp anything else do this...
rotate the 2 nipples of the dizzy 180 degrees
for example.... rotate it half turn and try again;... they are one way only.. so if u have it 180 deg away(1/2 way) it will not fit.... it happened to me before...
Old Aug 29, 2002 | 07:38 AM
takeheed's Avatar
Default Re: alignment of the intake cam and distributor? (JDM EF9)
awe ****, ill go do that right now.thanks
Old Aug 29, 2002 | 10:46 AM
takeheed's Avatar
ok,i did that and it wasnt as bad as the other side,but still not quite right.so i just threw it back together re torqued everything and put my new timing belt onand it seems like the belt is one slot off.but i cant turn the cam gear becase it wot be in the right spot .aaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhh god damn this is the first time ive done a swap on a honda and i feel like im ****** everything up b4 i even get the motor in my car!@!!
Old Aug 29, 2002 | 07:51 PM
serious crx's Avatar
the distributer is 180 degrees off
bowtieboy911
Aug 13, 2011 12:36 PM
RYan McG.
Dec 31, 2006 12:33 PM
Aquafina
10
Nov 20, 2005 01:27 PM
Mentat Ghola
Oct 21, 2004 04:36 PM
IN VTEC
Jul 5, 2002 06:00 AM
