Project RHD
Old Sep 30, 2009 | 06:01 AM
notmightydx's Avatar
Default Project RHD
my RHD project, conversion was done prior to me taking ownership, Vsmhatched did the conversion and its literally flawless!!!! now i will be adding my own touches to it and making it as close to perfect as possible.
I'll start with some pictures before i ever touched it. Yes RHD conversion was performed by Vsmhatched.
Old Sep 30, 2009 | 06:10 AM
Default Re: Project RHD
here are some progress pictures. my ultimate goal is to have a badd *** head turning summertime only dailt driver LOL. estimated completion date is set for may 24 2010 my birth day present to myself. i manage a body shop so i have all the resorces, now i just need the funds haha
started with a few OEM goodies from honda to pretty much complete the engine bay, over flow tank and bracket, prop rod clip, and radiator bushing
close up of the hardware i used to mount the overflow, yes all engine bay hardware will be matched stainless washers and allen headed bolts EVERYWHERE
passenger side 1/4 had some door dings and minor rust that i cut out patched with metal and door skin glue then applied filler to make smooth
once i was happy with it i applied 3 coats of BASF primer 10 minutes flash time between coats
Old Sep 30, 2009 | 06:21 AM
then i tackled the tailgate which had some dings and i wanted to fill in the -H- logo
there was some surface rust/crap build up where the gate mount to the hinges so i used this handy dandy combo to clean all off!!!
BEFORE:
AFTER:
the gate is finished just waiting for primer.
Old Sep 30, 2009 | 06:28 AM
NOW i am working on the drivers side 1/4 which has previously been poorly repaired !
measure twice cut and trim once!!!!!
i since have applied 2 coats of body filler and sanded them down, and have applied the first coat of final glaze putty ill get some more pictures up later tonight.
Old Sep 30, 2009 | 08:15 AM
koucex's Avatar
Very nice work. This makes me miss working in a body shop and doing side work too.
Old Sep 30, 2009 | 01:18 PM
raldava's Avatar
looks like you been busy
Old Sep 30, 2009 | 01:24 PM
thanks guys! yeah i have been busy, when i first aquired it i drove it for about 300-400 miles. then it went in to teardown mode! it will be a nice street car when its all said and done. thanks again i should have an update by monday for sure, i just got my new rear bumper so im gonna fit that and finish my body work on the drivers side over the weekend... thanks again
Old Sep 30, 2009 | 07:38 PM
stanky finger's Avatar
wow thats some major work bro. nice job keep it up.
Old Oct 1, 2009 | 12:28 PM
bakertime's Avatar
Quality work man, nice attention to detail!
Also, I like the hybrid emblem...haha.
Old Oct 1, 2009 | 06:58 PM
prelude1897's Avatar
Good stuff
Old Oct 1, 2009 | 07:21 PM
vsmhatched's Avatar
lol, its from a toyota prius
Old Oct 1, 2009 | 09:21 PM
blue2000em1's Avatar
So happy to see you're using Basf products.
Old Oct 2, 2009 | 04:25 AM
basf products are the best IMO. not to much of an update, i did strip 75% of the interior yesterday and put the interior harness on a "DIET" lol. basically all i did was remove/de pinn all the un needed wire like rear defroster, 3rd brake like etc.
pic monday for sure
Old Oct 2, 2009 | 09:56 AM
What Basf products you using Diamont or Glasurit??Either way both are extremely great.Looks to me like dp26 primer.
Old Oct 2, 2009 | 07:24 PM
ding ding ding on the dp26. we spray diamont, for the money i dont think theres anything comparable out there.
not much as far as body/paint update, the 1/4 will be finished by one of my body guys over the weekend. i have been busy cleaning up the interior wiring, going to remove all the rear interior brackets that i will no longer be useing. also going to tuck the interior chassic harness and complete respray in kawasaki lime green.
Old Oct 2, 2009 | 07:45 PM
adamrich33's Avatar
looking good, and nice 1/4 work, but just promise you will paint the underside of the hood. that engine bay looks clean enough to eat off of
Old Oct 5, 2009 | 08:43 AM
engine bay is MINT. i am going to go thru and weld up all the threaded holes, clean up the seam sealer and respray it.
Old Oct 5, 2009 | 11:07 AM
jdmcoupe07's Avatar
New User
nice job its looking clean.
Old Oct 6, 2009 | 09:36 AM
SykVSyx's Avatar
Not really feeling the plain looking valve cover, otherwise the car looks mint and great job with the body work.
Nice to see some serious attention to detail.
Old Oct 6, 2009 | 01:03 PM
valve cover i dig! im gonna paint it a different color, or get a HypeR valve cover
Old Oct 6, 2009 | 03:32 PM
shocker911's Avatar
def some nice body work...what color are you gonna paint it when you are all done with the change?
Old Oct 8, 2009 | 11:37 AM
SykVSyx's Avatar
I guess whatever colour you decide to paint the car, the valve cover could be colour-matched or something with a nice contrast.
Old Oct 15, 2009 | 08:03 AM
its update time, theres quite a bit. we pretty much completely stripped the car down to the dash wiring harness and engine so i can still move it around fairly easy. doors, fenders, hood, bumper, headlights, sunroof etc. enough chit chat on to the pics:
gutted inside coloum and dash harness is all that left:
stripped except engine bay:
i figured bins to organize would be a great idea:
door off ready to remove all the trim stuff:
one door completely stripped:-bleeder checking in on the build, he has been a big help so far
scraped up the seam sealer because i wanted it a little cleaner:
then i hit it with a cookie grinder, im gonna use 3m 5808 seam sealer before i paint:
last coat of aircraft stripper, this is way more productive than sanding and a LOT cleaner:
all done, need to sand with 220 and a few good coats of primer then its time to block sand:
got the roof fixed with a thin coat of bondo, needs a coat of glaze and some primer:
finally got the 1/4 done, aftermarket cover fits like OEM and i saved 170 buck!!!!:
Old Oct 20, 2009 | 09:29 AM
vectorsolid's Avatar
Good project photos. Nice job.
Old Oct 21, 2009 | 07:34 AM
a little update used aircraft stripper on the doors stuff work!!!
Mid progress...
all stripped off...
How we left er...
[/QUOTE]
