Another No budget single slamer build
Old Sep 26, 2009 | 10:37 PM
base-op.1320's Avatar
Default Another No budget single slamer build
Here is my most recent low budget single slamer build after I broke a retainer and bombed my b series motor in my civic. I probably have $3500-4000 in the whole car and plan on having a blast in it.
Daily Driver I stole from my wife
Eagle rods
Vitara pistons
Act clutch
60-1 turbo
spa manifold
Double backdoor intercooler
El cheapo wastegate and bov
Gangsta downpipe and chargepipe
Precision 1000cc with E-85
Tuned on Crome by me
Skinnykidsfabshop Gription bar
[/quote]
Old Sep 26, 2009 | 10:53 PM
FRANKBUILT's Avatar
Default Re: Another No budget single slamer build
Looks good how much power?
Old Sep 26, 2009 | 10:59 PM
I am shooting for enough to brake some tranny's probably around 450ish whp.
Old Sep 26, 2009 | 11:10 PM
DARKB20's Avatar
When are you going to dyno? How much boost?
Old Sep 26, 2009 | 11:13 PM
I don't dyno tune, just track tune. Probably start around 25psi and see what happens.
Old Sep 27, 2009 | 12:28 AM
jdm inc's Avatar
good luck! Keep us updated
Old Sep 27, 2009 | 03:48 AM
jjspec's Avatar
I likey! Nothing like inexpensive HP. Good luck with it!
Old Sep 27, 2009 | 07:55 AM
thanks, you guys having anymore of the sohc races down that way?
Old Sep 27, 2009 | 01:46 PM
2004es2's Avatar
That seems like a pretty high number with a stock head and intake manifold. I am also building a single cam with ge rods and vitara pistons but I am doing supertech valves springs and retainers wiat a port and polish job and I will probably barely hit 300whp. Then again I don't want anything to brake either. Good luck with the build and tune. Keep us updated with it.
Old Sep 27, 2009 | 01:55 PM
Cotterpin-PFI's Avatar
Ive built 3 eagle/vitara motors for my friends all of them with stock heads 2 of them make just over 400hp and have ran 11.0s and 1 was none vtec and both rev to 8200 the other made 326hp and get daily driven and beat to **** everyday and gets reved to 8000.None of them have ever had any problems.
Old Sep 27, 2009 | 02:07 PM
trickeng's Avatar
"starting around 25psi" sounds like your not scared to push things. 450 is a big number with a stock head, but good luck.
Old Sep 27, 2009 | 03:06 PM
I have a flange sleeved block and will probably be using cotterpins genius idea and attaching a ls b-series trans, so if this one breaks multiple times I could care less. The only way to learn what's weak is to break sh*t in my opinion.
Old Sep 27, 2009 | 03:12 PM
solo227's Avatar
450 can be done on a stock head... Good luck have fun
Old Sep 27, 2009 | 03:17 PM
jjspec's Avatar
Most definately. Probably next year early on. I put down 450 last weekend at a dyno event. Today I ran a personal best of 11.5 @ 129. I think gearing is killing me. I tried to turn it up 1 psi and something let go in the trans. That was on the 38th or 39th pass.
Old Sep 27, 2009 | 03:19 PM
You have the mph you need to go 10's for sure.
Old Sep 27, 2009 | 04:11 PM
jjspec's Avatar
I was trying to bring the boost in a little earlier to see if that would help my 330 but I put it in second and it quit pulling. I will do an autopsy this week and see what happened. Seems like 11.6 was a big barrier i was stuck at and I finally went 11.5 today. My wideband crapped out on me so no tuning happened today(the car has only been track tuned). Hopefully everything will come together and I will see what happens! Good luck on your build. Hope to see you next year!
Old Sep 27, 2009 | 04:56 PM
single cam fan's Avatar
lol thats how i see it to
Old Sep 27, 2009 | 05:08 PM
jjspec's Avatar
If it breaks it needs to be upgraded!
D-Rob
Jan 17, 2010 03:28 PM
fjt
May 16, 2005 06:38 AM
PrecisionH23a
May 3, 2004 12:29 PM
PrecisionH23a
Oct 6, 2003 08:35 AM
nekkedR
May 14, 2003 05:34 PM
