Anyone running a b20z turbo set up
First I did a search and my questions wan't answered, anyway
I just wanted to see maybe what you have done and what knda number's you putting down on the dyno as well as maybe some times. I'm thinking of doing this n my 88 crx and just wanted to see what to expect.
Thanks
Lee
Thanks
Lee
it will make 300 somthing with stock internals with vtec head and turbo.I have piston and rods only stock head and to big of turbo( need more boost) playing it safe. made 379whp@15psi running rich as **** ( need more tuning).You need to modifie the piston to clear the valves thats all unless you are using the stock head with it then you need to change the intake manifold to clear your hood....
[Modified by B20T, 11:07 AM 8/28/2002]
anyone running a straight b20 w/ turbo? (non-vtec)
https://honda-tech.com/zerothread?id=249834
try searching in the archives
https://honda-tech.com/zerothread?id=249834try searching in the archives
