cel 30 on m/t car
Old Sep 23, 2009 | 11:17 AM
tales sol's Avatar
Default cel 30 on m/t car
hey any ideas lads!
im working on a friends 95 coupe.
he has swapped in a b16 engine and using a EDM p30 ecu.
I have ran the extra wires for vtec to work and its working fine.
only problem is the mil is on and giving me cel 30.
thing is cel 30 is for auto trans cars?
im stumped, the car was and still is manual and the ecu is from a manual car too!
any help would be great,
thanks lads!
Old Sep 24, 2009 | 02:34 AM
tales sol's Avatar
Default Re: cel 30 on m/t car
bump
Old Sep 24, 2009 | 02:49 AM
RyanA's Avatar
You are sure it's not a code 3, MAP signal? If the ECU truly is a manual ECU, I'd say that is the code you really have. If so, check your MAP sensor wiring and make sure it's plugged into the right spot (TPS and MAP can interchange...)
Old Sep 24, 2009 | 03:07 AM
tales sol's Avatar
Thanks but its defo 3 LONG flashes!!
I have had the pleasure of mixing up the map and tps plugs before LOL.
When that happens the car wont rev up properly though where as this car is running/driving just fine????
I do quite a bit of work with hondas and im a qualified mechanic but at the min this one has me stumped!!!
Old Sep 24, 2009 | 05:40 AM
RyanA's Avatar
Double check your jumper settings inside the ECU. Make sure that it's not configured to be an auto right now. If it is, change the jumpers.
hondalove414
Mar 20, 2011 08:11 AM
what1118
11
Dec 25, 2007 06:06 PM
jays93eg6
Sep 25, 2006 03:38 PM
White98LS
May 4, 2003 08:12 PM
