Suspension Going Crazy. HELP!!!
I have front COilovers on my eg hatch with stock shocks (saving up for tokicos) when my car is just sitting, my front tires look with a little negative camber but the truth of the fact is in 3 weeks, my car ate up the outside of a 60% tire on the outside of it. yesterday my tires where starting to turn bald on the outside and after driving the car for 200 miles i started to see the metal on them. im running 205 40 17. I have no idea what is wrong. HELP!!!!
dude camber does NOT eat ur tires i probably have ur toe way offf go get an alignment ( by experienced i learned this)
my tires got literally chewed from the outside too
Was that a typo? You stated, you had wear on the *OUTSIDE* edge of the tire and you have negative camber? I have to say that doesn't sound right and I don't think an alignment will address it. Bad toe eats the *INSIDE* edge of the tire.
Have you checked your tire pressure? If they have gotten insanely low, then wear is a bit inpredictable. However outside wear is typically due to under-inflation which causes the tire to cup and you wear the edges of the tire, but not the middle.
Verify tire pressures before getting the alignment.
averyvm
Suspension & Brakes
Nov 2, 2009 10:32 PM
Paulybrownktown
21
Jun 29, 2009 03:35 PM
mycivicstoo(s)low
13
Jan 14, 2003 07:08 AM
