Strange tire wear question.
I was under my car (94 EX) tonight and noticed my front tires are worn almost completely bald on the inside. It looks like camber wear, but my suspension is all stock. I guess my camber could be screwed up anyway, though. The tires haven't been rotated as often as they should've been , but I figure that would wear the whole tire, not just the inside. So, do you guys think this was caused by me not rotating the tires often enough, or is it something else? Any input is appreciated. Thanks.
Re: Strange tire wear question. (mycivicstooslow)
i am guessing its your camber, is your tires slanted ? if so thats whats causing it or if your ride height is really low that can be the problem for the failure of the camber kit,
rotating the tires, perhaps. that is, if it's all stock. camber sounds like it needs to be fixed tho. wheels butterflying?
Re: Strange tire wear question. (edrop27)
if your toe adjustment is off, even if the suspension is stock, you will get weird tire wear patterns. change your tires asap b/c they will perform like *** in the rain, and then get an alignment... youll be all set
Re: Strange tire wear question. (euclid)
Oh they do perform like *** in the rain. Now maybe I know why. I hate to take it anywhere, but oh well. Thanks for the info.
An alignment should definitely do the trick. Keeping your tires rotated will promote even wear and will help keep the alignment in check
Re: Strange tire wear question. (delsolguy)
Do you have aftermarket rims? If so, check the offset. When I was younger, I took some rims off an old car of mine and stuck them on my Civic. Took me a while to figure out why my tires were bald on the inside and 1/2 tread on the outside.
I had the exact same problem with mine... 10k on new tires and the innermost ring was bald. Took it to Honda, they did the full allignment and found a bit of toe out.
Replaced the front tires that day and have put another 25k on them and they still look brand new.
Arbadacarba
Arbadacarba
Re: Strange tire wear question. (Dave421)
If your car is stock height, its your camber kit. You need to get your car re alligned. cost about 65 bucks for 4 wheel allignment.
Re: Strange tire wear question. (projectM)
There is no camber kit, the suspension is stock, not just stock height. But I'm definitely getting an alignment and new tires. I just don't understand why the tires would do this unless there's some way you can screw up the camber on stock suspension.
how would offset affect the tirewear? isn't offset just how far the wheel extends beyond the hub?
averyvm
Suspension & Brakes
11-02-2009 10:32 PM
Kyles ej1
01-08-2005 04:07 PM
