Honda S2000 Honda S2000
Clutch master cylinder question
Old Sep 22, 2009 | 12:00 PM
TypeR324's Avatar
Default Clutch master cylinder question
So I have been having some clutch problems for some time now and I think the cause may be my clutch master cylinder. I was looking at it the other day and it appears that the rod on the CMC that attaches to the clutch pedal is somewhat loose. Is this normal, I would have thought it should feel much tighter thus the reason I think it needs to be replaced. Any thoughts?
Old Sep 24, 2009 | 09:05 AM
TypeR324's Avatar
Default Re: Clutch master cylinder question
Anyone?
Old Sep 27, 2009 | 03:34 AM
Oleg's Avatar
CMC is bad when you see fluid seeping past the seals on the inside of the car. Thats a common problem. I dont know about it being loose part though...
Old Sep 27, 2009 | 12:02 PM
Francesco's Avatar
I would try adjusting the clutch pedal first from inside the car. If this doesn't cause a change for the better, then I would check out the slave cylinder. The cmc might not be the issue, but it is a possibility.
Old Sep 27, 2009 | 05:38 PM
4doorH22's Avatar
What are the symptoms of your problem?
Old Sep 29, 2009 | 08:30 AM
TypeR324's Avatar
I have tried adjusting the clutch multiple times, I have also had Honda adjust it once but it does not fix the problem. The specific problem I have is that the catch point is extremely high and the clutch pedal feels like it sticks somewhat when it is fully dperessed. I may try to replace the slave cylinder as that is a easy job and the slave is only 45 bucks I think.
Old Sep 29, 2009 | 09:15 AM
4doorH22's Avatar
More like $55, and the whole CMC is just $20 more than the slave, but no point in spending money if it doesn't fix your problem. Unless your clutch is fried, you really should be able to adjust the catch point with the rod behind the pedal. I'm sure you've tried rotating it in both directions?
Old Sep 29, 2009 | 10:05 AM
TypeR324's Avatar
Yup, I have tried both directions but no luck.
JLSpeed
Aug 15, 2009 07:22 PM
badass civic
Feb 28, 2009 05:32 PM
Black '97 GSR
Jan 10, 2006 06:20 PM
RiCE On IcE 2
Jun 22, 2005 07:10 PM
integsra
Jun 25, 2001 06:48 AM
