what injector size should i be running???
Old Sep 21, 2009 | 09:54 PM
mynameizstitch's Avatar
Default what injector size should i be running???
ok got almost everything complete now with the project. motor is b16a and i want to know what injector size i should be running. i was thinking maybe just some rc 310's will do the job but what do you think? also do you think my stock fuel rail will hold up or will i have to upgrade to like aem fuel rail or something like that? (trying to keep motor looking stock as possible since CALIFORNIA laws sucks and dont want to be %$#@ over when cops pop my hood). so all the after market bling or parts not needed i would like to keep them out. my car is BAR for B16 already so that is why i went with a B16 build so if they pull me over they cant say nothing because they wont know what is inside of the motor only the outside.
mods:
skunk2 intake manifold
Crower cams stage 2
Crower valves
Crower springs
Crower retainers
Crower rods
SRP pistons (with this whole setup to be at 11:1 cr)
Skunk2 pro series cam gears
Type r oil pump
Block guard for higher rpm's
besides the parts listed above the rest is all oem parts from the local honda dealer
***car will be tuned on crome with a p28 ecu hoping to get 190-200 hp on the wheel.
Old Sep 22, 2009 | 03:27 AM
non-VTEC's Avatar
Default Re: what injector size should i be running???
310cc will work for that much power.
Old Sep 22, 2009 | 06:29 AM
OH_1fstgsr's Avatar
So run your numbers here.
http://www.rceng.com/
Something between 310-370's.
Stock Fuel pressure is betweeen 45-55psi.
Old Sep 22, 2009 | 07:00 AM
yeah i was thinking either 310's or 370's should be perfectly fine.
Old Sep 22, 2009 | 12:03 PM
Mike95lude's Avatar
If it's the same price or very close in price, I would get larger than 310cc, since you can scale down larger injectors to feed the appropriate amount of fuel in Crome. So there are zero negative consequences for going a little larger that currently necessary for your setup. Plus if you ever sell them, you'll have more buyers interested in a larger injector and probably get more money for them.
Your stock fuel pump, fuel rail, and FPR are more than sufficient too...no point in "upgrading" them since you are tuning the setup with Crome.
Old Sep 22, 2009 | 01:32 PM
komat's Avatar
with 11.5compression lsvtec blox c cams
i was only using 270cc out of the 360cc
Old Sep 23, 2009 | 08:22 AM
American.Graffiti's Avatar
I agree with everything but the fuel pump. I would recommend upgrading that as cheap insurance.
Old Sep 23, 2009 | 08:35 AM
yeah ima upgrade my fuel pump for sure to a walbro 255. anyone think 190hp is reachable with my setup???
mynameizstitch
15
Oct 1, 2009 09:21 AM
mynameizstitch
Sep 29, 2009 02:45 AM
mynameizstitch
Sep 23, 2009 08:39 AM
EFbomb
Oct 31, 2007 11:36 PM
fast92hatch
27
Jun 10, 2007 12:20 AM
