maxbore throttle body be enough for my N/A setup???
ok do you think a stock b16 tb done by maxbore with a 64mm bore will be enough for my setup or should i get a 68mm after market tb??? i will be tuning this motor on crome with a rev limit around the 9,500 rpm neighborhood hoping to make around 190 hp.
here is my setup:
motor is jdm b16a
skunk2 intake manifold
Crower cams stage 2
Crower valves
Crower springs
Crower retainers
Crower rods
SRP pistons (with this whole setup to be at 11:1 cr)
Skunk2 pro series cam gears
Micropolish crankshaft
Type r oil pump
Block guard for higher rpm's
besides the parts listed above the rest is all oem parts from the local honda dealer
here is my setup:
motor is jdm b16a
Crower cams stage 2
Crower valves
Crower springs
Crower retainers
Crower rods
Type r oil pump
Re: maxbore throttle body be enough for my N/A setup???
I have wrote that guy on maxbore many times and never a reply. You are better off in giving up on him.
As for your question to be answered. Look up the stock specs of the Integra type r diameter and that should tell you the answer to your question, really.
mynameizstitch
10-06-2009 04:12 PM
mynameizstitch
15
10-01-2009 09:21 AM
