EG ex sedan abs 15/16 MC ... which other car could it bolt up to w/out changing BB?
Old Sep 21, 2009 | 12:09 PM
Charlie Moua's Avatar
Default EG ex sedan abs 15/16 MC ... which other car could it bolt up to w/out changing BB?
Yes i've searched & know about the EF ex 15/16 MC upgrade. But i have a free MC that I wan to to be able to use. I do not anyone telling me get a DC MC with DC brake booster cause i'm not looking to do that much work.
I found a 1995 civic ex sedan abs 15/16 MC.
I was wondering it would work as a upgrade for other 92-95 civic dx/lx/vx/cv brake booster?
I know that all EK (dx/lx/ex/hx) could upgrade to the ITR, +96gsr, 99-00si MC with out having to change out the brake booster.
Thanks
Charlie Moua
Old Sep 21, 2009 | 12:21 PM
worlds-slowest-EG's Avatar
Default Re: EG ex sedan abs 15/16 MC ... which other car could it bolt up to w/out changing B
15/16 is a larger bore than stock and is a good upgrade/ highly recomended to go along with a rear disc swap.
Old Sep 21, 2009 | 06:24 PM
yes I understand that 15/16 would be an upgrade over smaller eg ones from dx/lx/cx/vx which are 13/16.
the question is:
- will the EG ex sedan MC bolt up to all other EG brake boosters and without having to bend the brake lines much ?
Old Sep 21, 2009 | 06:32 PM
94EG8's Avatar
Seagull Management
Originally Posted by Charlie Moua
the question is:
No on both counts, you need the corresponding brake booster to go with it, Mounting flange/ears are rotated 90 degrees. And it uses one larger fitting than the non ABS version.
Just as a side note, if you try running a 15/16MC with otherwise stock brakes you will end up with a rock hard brake pedal as if you had no power brakes.
splickitysplat
Suspension & Brakes
Mar 10, 2009 10:13 PM
jdm4drSi
May 1, 2007 05:59 PM
JDM_SOHC
25
Apr 20, 2007 09:52 PM
ITR_EGG
Aug 15, 2006 07:23 PM
DerangedEG
Aug 15, 2003 04:43 AM
