d16y8 engine light??????
Old Sep 21, 2009 | 07:24 AM
rvd6669's Avatar
Default d16y8 engine light??????
Can anyone help me Im pulling a code of P1361 TDC Sensor Intermittent Interruption, What does this mean and how can i fix it?
Old Sep 21, 2009 | 09:41 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: d16y8 engine light??????
is your timing set correctly?
do you have the correct ecu and dizzy?
Old Sep 21, 2009 | 10:38 AM
rvd6669's Avatar
The timing is right and nothing else has been changed that i now of
Old Sep 21, 2009 | 11:00 AM
whiteciv88's Avatar
sometimes these cars throw faulty codes and sometimes fix them selfs but just do more looking into it and then just start with the cheapest part then work your way up if that makes sense
Old Sep 22, 2009 | 05:48 AM
I'm not Rick!
try a dif ecu and see what happens
Old Sep 22, 2009 | 06:27 AM
Former User's Avatar
If you clear the ECU, does the CEL code return? If the code returns, do you measure 350-700 Ohms for the TDC sensor? If not, replace the distributor housing.
M3THTICAL(EF)
Jul 24, 2016 08:24 AM
mengy007
13
May 15, 2006 02:30 PM
THE94GSR
Jun 25, 2004 05:07 AM
wickedxboi
Oct 28, 2003 08:12 PM
ocbeta
Jul 5, 2002 03:37 PM
