screws for slicks. Where do you get?
Old Sep 20, 2009 | 06:52 AM
TegraGSXR's Avatar
Default screws for slicks. Where do you get?
I remember there was a post awhile ago about them but didnt find anything in the search. just wondering where i can get a set for my lenso's. thank you
Old Sep 20, 2009 | 07:05 AM
Turbocivic94's Avatar
Default Re: screws for slicks. Where do you get?
Summit got them
Old Sep 20, 2009 | 08:09 AM
Boostin Ex's Avatar
I got mine from jegs don't know whether or not they all come with the drill bit but the ones from jegs does http://www.jegs.com/i/JEGS/555/65040/10002/-1
Old Sep 20, 2009 | 08:23 AM
TimKennard's Avatar
I got mine at my local Shuck's Auto Parts store. Moroso brand. Not sure if you have one there though. But ya, summit and jegs both have them.
Old Sep 20, 2009 | 08:36 AM
jdm inc's Avatar
summit or jegs.
Old Sep 20, 2009 | 10:40 AM
boostedcivicsir's Avatar
Mr. Badwrench
anywone that has mr gasket, will have them. i do about a set a week.
just remember, drill the hole, then run the screw through the hole without the tire. basically tapping the hole.
then mount the tire and screw the rim into the tire.
Old Sep 20, 2009 | 11:57 AM
oneqkfodo's Avatar
You can also go to ipgparts.com and order the screw kits from james.
Old Sep 20, 2009 | 11:59 AM
jnv255's Avatar
Summit
Old Sep 21, 2009 | 02:58 PM
TegraGSXR's Avatar
ok. I ordered them from summit. I typed in slick screw and couldnt find any. For some reason I never thought tire screw! so I have to take the tire off to install them? Thanks
Old Sep 21, 2009 | 03:24 PM
1992Si's Avatar
local hardware store.
Old Sep 21, 2009 | 06:03 PM
Mr. Badwrench
yes dismount them. drill them, run the screws through each hole with a drop of oil on them. they gove you like 4 extra. (assuming you use 8 on each bead)
then remount the tire, and pin the slicks.
Old Sep 22, 2009 | 03:46 AM
XXXRacing's Avatar
james @ ipgparts.com, he gives you a nice template to use. Well worth it.
Old Sep 22, 2009 | 05:17 AM
tepid1's Avatar
x2
Old Sep 22, 2009 | 07:25 AM
Innes's Avatar
here is a little write up i did a bit ago on this
https://honda-tech.com/forums/drag-racing-36/tutorial-how-install-rim-screws-2374524/
94civiccupew/b7
Mar 22, 2014 04:07 PM
NABeastRR
Feb 11, 2012 06:32 AM
castrol_civic
Oct 25, 2006 06:33 PM
raene
May 5, 2003 08:09 AM
MechE00
Apr 9, 2003 07:45 PM
