screws for slicks. Where do you get?
I remember there was a post awhile ago about them but didnt find anything in the search. just wondering where i can get a set for my lenso's. thank you
Re: screws for slicks. Where do you get?
Summit got them
I got mine from jegs don't know whether or not they all come with the drill bit but the ones from jegs does http://www.jegs.com/i/JEGS/555/65040/10002/-1
I got mine at my local Shuck's Auto Parts store. Moroso brand. Not sure if you have one there though. But ya, summit and jegs both have them.
summit or jegs.
anywone that has mr gasket, will have them. i do about a set a week.
just remember, drill the hole, then run the screw through the hole without the tire. basically tapping the hole. then mount the tire and screw the rim into the tire. |
You can also go to ipgparts.com and order the screw kits from james.
Summit
Originally Posted by boostedcivicsir
(Post 40024405)
local hardware store.
Originally Posted by TegraGSXR
(Post 40036190)
ok. I ordered them from summit. I typed in slick screw and couldnt find any. For some reason I never thought tire screw! so I have to take the tire off to install them? Thanks
then remount the tire, and pin the slicks. |
james @ ipgparts.com, he gives you a nice template to use. Well worth it.
Originally Posted by XXXRacing
(Post 40041885)
here is a little write up i did a bit ago on this
https://honda-tech.com/forums/drag-racing-36/tutorial-how-install-rim-screws-2374524/ |
