corner balancing your car.
Old Sep 18, 2009 | 08:13 PM
project504's Avatar
Default corner balancing your car.
I just tried to Balance my car the best I could today (I’ve never done it before)
Now I tried to get Left front and Right Front as close as possible but in doing that it made my rear LH and RH off.
Do you this matter? I could keep messing with it. Just thought I would ask. Here are my numbers
LF 717 LBS RF 718
LR 438 RR 320
That about 65.5% front 35.5% rear.
The other thing is the car is sitting nicely right now aswell.
any advice or tips on what has worked for you would be great.
Later justin
Old Sep 18, 2009 | 08:37 PM
ShawnR's Avatar
Default Re: corner balancing your car.
ask miller we got my car pritty close in the front, the rear isnt as important.
Old Sep 18, 2009 | 08:50 PM
BoostedJeff's Avatar
pritty
Old Sep 18, 2009 | 09:02 PM
Mike@CCT's Avatar
Formerly Mike@TSR
you got a pritty mouth
Old Sep 19, 2009 | 12:32 AM
V-SPEC 1's Avatar
Bump for more info please.
Old Sep 19, 2009 | 04:38 AM
ALL IMPORT's Avatar
i would thing the rear is important. as load travels back diff wight can make the car twist. assuming u were sitting inthe car your *** was making the LR heavy loose some weight, lol
Old Sep 19, 2009 | 09:05 AM
project504's Avatar
yes I was sitting in the car. but I think I made alot progress when I started the car weighed
LF 794 RF 627
LR 352 RR 406
so you see the Lr gets weight added to it as the FR gets weight added.
Old Sep 19, 2009 | 12:43 PM
tepid1's Avatar
Not like you would think. If it were RWD, then yes, it would be more important....
What Shawn said is correct.
Old Sep 19, 2009 | 02:30 PM
welfarepc's Avatar
cant wait to see you back out at mission Justin
we gotta line up!
Old Sep 19, 2009 | 04:20 PM
ALL IMPORT's Avatar
If u got the sam springs in the rear & diff weight one will squat more thus changing the angle of the car. I know whaT your sayin about the rwd when u see them twist our bug had that problem & we just fixed that
Old Sep 20, 2009 | 12:20 PM
tepid1's Avatar
Again.... on a FWD car it's not that important. If your suspension is doing it's job, both dampening and rebounding properly, it's not that big of a deal. A unibody car doesn't flex like a v8 domestic....
Old Sep 20, 2009 | 01:59 PM
miller's Avatar
Having the correct suspension in the car is a big factor. If you have control over the rebound and dampening it makes it alot easier to counter act the way the chassis moves upon the initial hit and shifts when there is different weights in the back.
Find a chassis setup guy and have them go over the car with you. Set ride height, corner balance, align and then test with you to get the car to do what it is supposed to do.
Old Sep 20, 2009 | 02:18 PM
project504's Avatar
cool thanks for the helps guys
my suspension is pritty good.
I run full race traction bars 550LBS spring in the front and 1000LBs on the rear and I run ground control advance designs shocks. They have full rebound and dampenning I am running them full stiff all around.
( Idon't know if that's the right thing to do or not)
as for chassis setup guy I am at least 500 mile from anyone that can help me, so it's looks like it's just me and couple of my road race dubddies and whatever info I can get from you guys.
thanks every bit of feed back helps.
Later justin
Old Sep 20, 2009 | 03:26 PM
SkunkedRex's Avatar
Isn't there also a nother way with out adding weight??
*( Now what im talkin about is a Car being equipped with adjustable Spring suspension)*
*LIKE
LF_ 717 RF_ 691
LR_ 352 RR_ 406
You would rase up the DRIVER'S ride hight to put weight on the pass' front???
Its a why of doing it
If im wrong correct me,.. My knowledge coming from a 7yr NMCA an NMRA winner, an chassis builder ~ Lance Munden
Old Sep 22, 2009 | 11:44 AM
Da Moose's Avatar
Yes the rear matters. And what is even more important is your diagnol %. Bet you anything that your car will go straighter with the diagnol at 50%. Then with the front at 50%
Old Sep 22, 2009 | 11:55 AM
jj07's Avatar
OG Fabricator
I know some secrets just dont get shared, but approximately what is the optimal percentage front to rear weight?
Old Sep 22, 2009 | 12:23 PM
Da Moose's Avatar
70-30 seems to work very well. Anything over 75% front starts getting real light in the rear when the chutes come out.
Old Sep 22, 2009 | 12:25 PM
Da Moose's Avatar
Originally Posted by project504
numbers
LF 717 LBS RF 718
LR 438 RR 320
Thats awesome 101%
CRX_RR
Jun 24, 2015 07:03 AM
Junior1023
Oct 30, 2013 11:33 AM
Aeka GSR
Feb 28, 2003 06:27 AM
zer0zer0 TypeR
Jun 1, 2002 03:19 AM
type r 01-1063
Feb 20, 2002 08:49 AM
