Strength of Earls Stainless Steel braided lines?
Old Aug 27, 2002 | 08:36 PM
R-1303's Avatar
Default Strength of Earls Stainless Steel braided lines?
I have my Earls stainless steel oil return line touching my downpipe. Will the line hold up to the extreme temp's of the downpipe.
"I heard"..that it would take a torch to go through the lines and it wouldn't be any problems with it touching the down pipe.
Advice Please...
Old Aug 27, 2002 | 09:16 PM
R-1303's Avatar
Default Re: Strength of Earls Stainless Steel braided lines? (R-1303)
come on! i know half of you are using these lines!
Old Aug 27, 2002 | 09:24 PM
Arturbo's Avatar
Better than steak
25 Year Member
Do not let it touch the downpipe. Its made to hold pressure, not to withstand a hot downpipe.
Old Aug 27, 2002 | 09:26 PM
PrecisionH23a's Avatar
definetely move it away from the dp, the steel with trap heat which will probably burn through the rubber sooner or later... i recommend buyin a heat wrap for the line.
Old Aug 27, 2002 | 10:27 PM
R-1303's Avatar
Default Re: Strength of Earls Stainless Steel braided lines? (GudeH23a)
Will the heat wrap withstand the heat from the down pipe?!?!?.....and daam i got to but an new oil pan then.
Old Aug 28, 2002 | 09:17 AM
98civicEX's Avatar
can u just re route the line and use wire ties?
Old Aug 28, 2002 | 09:27 AM
dustin's Avatar
Default Re: Strength of Earls Stainless Steel braided lines? (98civicEX)
You don't want it touching. My first oil return line sat about 1/4 inch away, not touching, and it eventually began to melt the rubber THROUGH the metal...
Old Aug 28, 2002 | 09:51 AM
CovertFI's Avatar
Default Re: Strength of Earls Stainless Steel braided lines? (dustin)
it should be 300 degrees, same as regular rubber hoses
Old Aug 28, 2002 | 09:58 AM
GSRwBOOST's Avatar
Default Re: Strength of Earls Stainless Steel braided lines? (CovertFI)
**** mine is touching and has been....
edit** mine is touching the i/c pipe..
Old Aug 28, 2002 | 02:26 PM
Sprockets's Avatar
This is what you need...
http://www.holley.com/HiOctn/ProdLin...HC/730006.html
Old Aug 28, 2002 | 02:33 PM
dustin's Avatar
Default Re: Strength of Earls Stainless Steel braided lines? (Evil Beaver)
That stuff just insulates, it's silicone or something similar (I have some of it) and it won't keep it from melting
Old Aug 28, 2002 | 07:31 PM
Sprockets's Avatar
It's supposed to be able to handle up to 2000 degrees fahrenheit for up to 15 minutes. It's not just insulation. Other than making sure the hose doesn't touch it's still the best option. It's better than Thermo-Tec.
Old Aug 28, 2002 | 08:56 PM
R-1303's Avatar
to dustin. i visited you web site and it help me very much with my turbo install!...will somebody please post pics of there oil return setup? (please). and also the thermal wrap won't with stand the temps of the down pipe?
Old Aug 28, 2002 | 08:58 PM
Arturbo's Avatar
Better than steak
25 Year Member
It wont withstand it if its touching it. Just route it so its not touching the downpipe.
art
Old Aug 28, 2002 | 10:37 PM
R-1303's Avatar
Default Re: Strength of Earls Stainless Steel braided lines? (Arturbo)
art
Art, can you please post pictures of your setup? i remember seeing it once but i can't find it no more...i have a drag 3 kit on a b18c5.
Old Aug 28, 2002 | 10:40 PM
Arturbo's Avatar
Better than steak
25 Year Member
I dont have any pics of it. It looks very much like dustin's..
Old Aug 29, 2002 | 10:25 AM
R-1303's Avatar
So its safe to go around the downpipe?!?! i thought the bend back up towards the pan would be to much since the only thing returning the flow of oil is gravity. Thats why tried to go between the down pipe for the most direct flow.
[Modified by R-1303, 7:25 PM 8/29/2002]
Old Aug 29, 2002 | 10:35 AM
dustin's Avatar
As long as it is downhill the entire way it's fine.
Old Aug 29, 2002 | 11:23 AM
TurbothisLS's Avatar
can u list the link of your website? i will probably be needing help for my own turbo setup
thanks
Old Aug 29, 2002 | 12:17 PM
dustin's Avatar
Default Re: Strength of Earls Stainless Steel braided lines? (TurbothisLS)
http://imglib.************
vladd
Aug 19, 2006 06:39 PM
G U E C O
Dec 20, 2003 04:51 PM
igo4bmx
May 1, 2003 01:08 PM
igo4bmx
Apr 25, 2003 10:01 AM
Damon B.
Feb 4, 2002 06:50 PM
