Transmission & Drivetrain Gearboxes, Differentials, Clutches
gsr popping out of 4th after cuff install.
Old Sep 17, 2009 | 05:15 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default gsr popping out of 4th after cuff install.
i put a trans cuff in my trans and now when i shift the car to 4th it feels like it not going in completely and when i let out on the clutch it pops right out. i pulled the trans back out and i had a spare case so i cut a hole in the top of it so i could see whats going on. from what i can see the synchro sleeve dont seam to be sliding completely onto the synchro part of the gear. i dont understand what could be doing this. i took a few pics so you could see whats going on. i may just buy a new synchro sleeve and sleeve gear and see if that fixes it. also is it normal for the main shaft to sit a little bit higher than the counter shaft when the case is off. it sits about 1/16" higher that the main shaft and im starting to think this may be my problem cause thats about the size of the gap when i try to go to 4th.
Old Sep 17, 2009 | 07:28 PM
Honda Bull's Avatar
Default Re: gsr popping out of 4th after cuff install.
Take a pic of the sleeve down in 3rd the whole way. I can't see the gear or sleeve/hub being an issue if it physically can't travel the whole way in the manner that it is.
Also, it's normal for the CS to sit a bit lower. It raises up to flush when you lock the c-clip in place.
Old Sep 17, 2009 | 07:49 PM
1QwIkEf's Avatar
ill try to get pics tomorrow when its in 3rd. i took the pics while it was in 4th to show that it not going into 4th completely.
corpsebesideme
Jan 8, 2018 01:40 PM
Shaun_
Mar 3, 2016 11:50 AM
LOWLUDE22
Dec 2, 2015 06:02 PM
mrbuddha
Aug 16, 2010 07:53 AM
