possible a/c leak?
ok so a while ago i replaced my compressor (replaced o rings also) and it was running fine for a while. now for about the past 2 weeks or so i had to refill my ac like once a week and now i filled it up yesterday and i went in my car today and it already needs to be refilled. i dont see any holes or pinches in the line anywhere. where could the leak be coming from?
i also want to meantion that since the wiring is messed up due to the old owner (still sorting this out) i have the compressor on all the time. (constant power once i turn the car on) could this also be the problem? i know the compressor is good because if i fill it up the ac blows too damn cold lol. please help im dying lol
If nothing immediately jumps out at you, you may have to find someone with a refrigerant leak detector.
P
the low pressure or discharge hose is prone to leak becoause of the severe bend it has (depending on year model). I replaced both flex hoses and o-rings at the compressor on my 95 and it worked like a champ. Like others said...looks for wetness on the lines etc and you will find your leak.
put some dye and only about 8-10 oz freon freon in the a/c system,use a black lite to locate the leak or have a shop chk for leaks before you start replacing parts
So first you need to get that wiring problem straightened out, even if it does cycle when the A/C is cold enough. There are several other reasons why it's not good for your compressor to be running as soon as the engine starts.
And please don't put any more refrigerant in your system until you get the leaks taken care of. In addition to wasting your money, you're contributing to global warming because R-134 is a greenhouse gas. If your car is older than 1994 and takes R-12 (freon) instead, I don't even want to talk to you if that's what you've been doing. That's just totally irresponsible, in addition to being illegal.
Good luck!
drpapijr196
Jun 15, 2011 02:17 PM
