Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
ac compressor gone bad :(
Old 06-01-2011, 01:15 PM
drpapijr196's Avatar
Post ac compressor gone bad :(
hey guys how you doing i have a honda accord 2003 LX today i was driving and i tride to put my ac but i was only blowing hot air i tride putting gas in it but it was already full now iam trying to buy a new compressor can you reommend any places
thanks jr
Old 06-02-2011, 11:23 PM
Plead da Fif
It Wasn't Me's Avatar
Default Re: ac compressor gone bad :(
Are you sure the compressor is the problem? Have you checked the Power Transistor? What about the compressor relay or fuse?
Don't just assume that you need a new compressor, they're rather costly and you'd be kicking yourself for buying one if it didn't fix the problem.
Old 06-06-2011, 08:17 PM
slowcivic2k's Avatar
Reference this instead of throwing parts at your car, why waste your money, when you can save, and learn a little at the same time...
https://honda-tech.com/forums/tech-misc-15/%2A%2A%2Aair-conditioning-c-guide-how-works-when-doesnt%2A%2A%2A-2900177/
Old 06-14-2011, 08:51 PM
cncaliguy's Avatar
First, make sure the clutch engages the AC compressor before replacing the compressor.
Second, it might have a leak so a freon refill might not do anything. That leak introduces moisture into the system and entire loops needs to be repaired then vacuumed, then refilled properly based on the temps and pressures.
Even if they install the new AC compressor they have to look for the cause of the problem so take it to a professional.
Old 06-15-2011, 02:17 PM
BLKFLSH's Avatar
The compressor clutch and stator (coil) were changed on my car. The A/C would work breifly sometimes, then start blowing warm air. I think the clearance on the clutch was more than it should have been, and that caused the clutch failure.
baybay
08-26-2018 02:39 PM
le0ftw
09-01-2014 06:50 PM
jasrams
Honda Civic (2001 - 2005)
04-23-2012 08:59 AM
Turbo E
08-08-2006 08:59 AM
jlamaster
10-01-2004 07:12 PM
Quick Reply: ac compressor gone bad :(
