Catch Can Setup on OBD1 B18a1 Block/ITR head
Old Sep 16, 2009 | 08:01 PM
92integraVTECgsr's Avatar
Default Catch Can Setup on OBD1 B18a1 Block/ITR head
I want to add a Catch Can/PCV setup to my LS/VTEC. Right now I am using the stock system and want to upgrade due to high crankcase pressure.
What would be the best setup and how would I go about getting it setup?
Would I remove the black box and put something there? If so, how? because the black box just sits in there and has an O-ring on it to make the seal. That is pretty much all I am confused about.
Old Sep 16, 2009 | 08:07 PM
vtechjunkie's Avatar
Default Re: Catch Can Setup on OBD1 B18a1 Block/ITR head
You will have to get a freeze plug for the hole. I am doing the same thing and was wondering what to do about the pcv valve. Just remove it?
Old Sep 20, 2009 | 10:09 AM
How is the freeze plug going to stay in the hole if its not threaded? If I take the stock breather box off the back, it is just a smooth hole, there are no threads to screw anything into back there.
Old Sep 20, 2009 | 02:55 PM
DC_Legacy's Avatar
The freeze plug will be fine, just clean the hole with alcohol or gasoline once you remove the oem breather box then dab some permatex or hondabond around the edges of the freeze plug then tap it in slightly until its snug.
97mm_EH3
Apr 12, 2011 09:46 AM
GoSickemRobert
Apr 11, 2011 08:09 AM
ys1civicsi
Jan 1, 2009 07:09 AM
SIXTY-1HATCH
Dec 26, 2006 12:07 PM
highmilehatch
Jul 7, 2006 05:38 AM
