CEL After ECU Swap
Old Sep 15, 2009 | 12:05 PM
zerovandez's Avatar
Default CEL After ECU Swap
So I have an 04 EP3. The ECU got stolen and I replaced it with an ECU from a base model RSX. It's part number is 37820-pnd-a09. It works and all but the CEL is on. I haven't pulled any codes yet but I was wondering what can possibly turn on the CEL. The CEL was not on with the actual EP3 ECU. **** out of luck and just get the right ECU?
Old Sep 15, 2009 | 12:08 PM
nahonda04's Avatar
Surje.motorsports
Default Re: CEL After ECU Swap
it may have to be rekeyed? is your immobilizer plugged in?
Old Sep 15, 2009 | 12:19 PM
zerovandez's Avatar
i took it to honda and had them rekey it. Everything works just fine. The car runs smooth etc. I thought the immobilizer was built into the ECU. It's seperate?
Old Sep 15, 2009 | 12:27 PM
nahonda04's Avatar
Surje.motorsports
yeah it is seperate, except i cannot tell you where it is due to HT forum rules....check over at clubep3, see if they can tell you
Old Sep 15, 2009 | 12:31 PM
zerovandez's Avatar
But if it wasn't plugged in, then the car wouldnt start right?
Old Sep 15, 2009 | 12:43 PM
josh's ep3's Avatar
Function > Form
You should check what codes it's throwing before you speculate. You could be completely off and just worrying yourself for nothing when it's a possibility that it could just be a misfire or something normal.
Old Sep 15, 2009 | 12:56 PM
zerovandez's Avatar
^^Yeah. But the ECU I stated should work without throwing codes even though it's not meant for the car right? Can anyone comment on that?
Old Sep 15, 2009 | 01:13 PM
josh's ep3's Avatar
Function > Form
It could be because they have different intake manifolds. I'm not sure if that would affect anything but, maybe it's throwing off the A/F mix thus causing a code.... hence the recommendation of checking the codes before jumping to conclusions.
skyliner34life
Engine Management and Tuning
Jul 5, 2016 06:05 AM
h0nda n00b
Feb 27, 2014 09:13 AM
rick_rabies
Aug 24, 2009 06:22 PM
drumminforev
19
Oct 6, 2006 12:12 AM
