Is there a good Spray paint primer??????
If anyone is reading this i need helpppppppppppppp.... i got a d15y7 engine i swap the head for a vtec head from a d16 engine with the p28 ecu that i get from a 93 civic ex automatic (my car is a 92 civic dx sedan) the car is runnig good except for the code 19 that is showing, i look that up and its a code from some automatic transmision sensor or whatever but my car is manual and i heard that if the check engine light in a vtec motor is on the vtec will not work so my question if theres any way that i can fix it or i have to get another ecu from a manual car????
The spray can primers are no where near as good as the catalyzed ones you shoot in a gun. I was trying to get away with using rattle can SEM primer for a few spots I sanded through, and it just doesn't even come close. The rattlecan stuff sanded off instantly, even with a few medium coats. However, if you're set on that then SEM is quality stuff.
falcon93si
35
May 12, 2016 12:21 PM
oldjackman
22
Nov 16, 2014 06:45 AM
Manny 77
30
Oct 13, 2009 12:46 PM
97civic07gsxr
12
Feb 14, 2009 10:50 PM
