Vtec hits but no more speed????
Old Aug 27, 2002 | 04:04 PM
B18C-Hatch's Avatar
New User
Default Vtec hits but no more speed????
i just got a JDM B18C and the egine runs fine except it does not pull when i hit vtec, i hear it but is does not do a damn thing??
it hits v-tec at like 4400rpm and 5600 rpm but you can't feel it at all and a 4 door gsr is keeps up and i am in a 2100lb hatch??
if anyone has any ideas on what the problem is please post, thanks
Old Aug 27, 2002 | 07:33 PM
lazy bum shaughn's Avatar
Default Re: Vtec hits but no more speed???? (B18C-Hatch)
Maybe you think that the VTEC is wired up but it's really not. Check your sensors and all that other mess.
tinkerbell's Avatar
find hte VTEC solenoid on hte engine and unplug it.
go for a drive and see if it feels the same...
t..
Old Aug 27, 2002 | 07:40 PM
98DC2-ITR's Avatar
Default Re: Vtec hits but no more speed???? (tinkerbell)
If he unplugs the solenoid the ECU will go into "Loop Mode" and it will not run right anyhow. This will not work. Flash the ECU codes and make sure you have none. You might not be getting the secondary butterflies "IAB" kicking in. If this is the case you should have a CEL. Any problems relating to wiring etc when it comes to VTEC etc will show up as a CEL hence flash the ecu codes.
Old Aug 27, 2002 | 07:42 PM
tinkerbell's Avatar
Default Re: Vtec hits but no more speed???? (4thapack)
WTF?
what is loop mode?
it wont go into "limp mode" cause of a VTEC solenoid!
not every CEL makes teh ECU go into limp mode!!!
t..
Old Aug 27, 2002 | 07:54 PM
Kamin's Avatar
WTF?
what is loop mode?
t..
loop mode
LMAO
and correct, no limp mode
only major things will send the ecu into limp mode.
Old Aug 27, 2002 | 08:09 PM
B18C-Hatch's Avatar
New User
Default Re: Vtec hits but no more speed???? (KAMiN)
ok i will check the ECU, but shoud i try unpluging the vtec soleniod?? also would the ecu flash a code if the solenoid is broke (shipping) and if the sensors are broke i thought the engine just runs in safe mode?
thanks for the responses
Old Aug 27, 2002 | 08:45 PM
tinkerbell's Avatar
sorry - i had assumed you had checked for codes!!!
silly me!
assuming makes and *** out of U and ME!!!
check for codes! ad report back...
if there are no codes - then pull your solenoid plug - you will get a CEL or MIL (on dash) but it will not go into limp mode.
when you have the solenoid disconnected VTEC wont engage, this way you can tell the BEFORE and AFTER feelings of VTEC/nonVTEC...
t..
Old Aug 27, 2002 | 09:08 PM
B18C-Hatch's Avatar
New User
ok thanks for the reply, will check back tomorow with more info
Old Aug 28, 2002 | 03:42 PM
AlterEgo's Avatar
Important, overlooked possibility... check your oil level... it needs to be full.
Old Aug 28, 2002 | 03:50 PM
poison's Avatar
Default Re: Vtec hits but no more speed???? (AlterEgo)
Old Aug 29, 2002 | 05:03 AM
b20guy's Avatar
CEL???? Oh you mean MIL...
Old Aug 29, 2002 | 03:07 PM
tinkerbell's Avatar
Default Re: Vtec hits but no more speed???? (b20guy)
do not start this AGAIN!
t..
Old Aug 29, 2002 | 09:10 PM
92SiB18C1's Avatar
I know CEL, but what MIL stand for?
Old Aug 29, 2002 | 09:58 PM
R_yd's Avatar
Default Re: Vtec hits but no more speed???? (92SiB18C1)
CEL = check engine light
MIL = malfunction indicator lamp/light
but we all understand each other
Old Aug 30, 2002 | 06:45 AM
Ricky Rojales's Avatar
WTF?
what is loop mode?
t..
loop mode
LMAO
LOL... one word: Viagra
Old Aug 30, 2002 | 01:25 PM
madman604's Avatar
are you using the ECU that came with the motor or the Civic one? Civic ECU wont give a CEL.
Old Aug 31, 2002 | 12:21 PM
keebler65's Avatar
also kamin posted a nice write up on VTEC trouble shooting steps. you may want to take a look at it. funny how good that search button works.......https://honda-tech.com/zerothread?id=164863
Old Aug 31, 2002 | 02:04 PM
B18C-Hatch's Avatar
New User
Default Re: Vtec hits but no more speed???? (keebler65)
i am using the JDM B18C ecu
DC2tuner86
Jul 22, 2010 05:25 PM
error2k
Mar 3, 2010 12:47 PM
dougk1401
Dec 7, 2009 08:55 AM
94ludeh22
Nov 16, 2005 07:14 AM
tuckin15s_8315
Sep 28, 2005 09:35 PM
