Starter going bad?
Old Sep 13, 2009 | 04:29 PM
lawlss's Avatar
Default Starter going bad?
a couple of weeks ago my car died at work so i though it was the battery so i replaced that. 2 week later which is last night i tried to start the car it wouldnt start again i was like DAMN the battery again?!?!?! so i called my friend come jump me up again. and it would start up fine. once i drove home. i turn my car off see does it start up again it wouldnt. so i give my friend a call again he said tried hitting the starter see does it start up and it did. what i dont understand if if the start is going bad why would it start up when when the car is getting jump. Now everytime when my car doesnt start i just start hammer on the hammer and the car would start up. so what the problem is it the start? but why would it start up if i jump the car?
Old Sep 13, 2009 | 04:42 PM
dgerej2's Avatar
Default Re: Starter going bad?
It may be your battery. Your battery should test above 12v when your car is off as well as on. Check a hanes or chilton manual. Your alternator recharges your battery while your car is running. If your battery acid is old it will not receive good charge from the alternator. If you have allready bought a battery from auto zone they will replace it for free if within 2 years, otherwise they will charge 20 something bucks(bring the orginal battery to the store). Also make sure you do not have any corrosion leading from your battery + to starter cable along with your + to engine bay fuse box. You may also check to see if your starter is recieving proper voltage with a voltmeter. Starters also tend to wear, you may need a new one.
Old Sep 13, 2009 | 05:18 PM
thecruzs2007@yahoo.com's Avatar
when you turned the key did it make a clickin sound? were your head lights workin?
Old Sep 13, 2009 | 05:46 PM
lawlsss's Avatar
when i turn my key on the first time i hear click noise from the passenger side. after than it just silence when i turn the key it wont start. but everytime i when my car dont start i just go knock on the starter and my car will start. so could it be the start?
Old Sep 13, 2009 | 06:10 PM
SlickEJ8's Avatar
so do your lights work?
Old Sep 13, 2009 | 06:14 PM
SoullessJapaneseMachine's Avatar
IIRC it should be around 12V with the engine off and 13-14V running. If his starter works fine with a jump, my money is on the battery being bad.
Old Sep 13, 2009 | 06:22 PM
JDMPHILEP91's Avatar
you might want to check your alternator...since your battery is goin dead, therefore your alternator is not charging your battery.
Old Sep 13, 2009 | 06:27 PM
SlickEJ8's Avatar
what he/she said check the voltage 12v koeo 13v-15v koer
MHDesigns's Avatar
Not necessarily. If it stays running than the alternator is likely fine, sounds like the battery won't hold enough of a charge. Batteries don't last forever. auto-zone does free tests.
Old Sep 13, 2009 | 06:31 PM
jason0123's Avatar
I had the exact same problem. Car wouldn't start got a jump and it started. Headlights were bright so I knew I didn't have a bad battery. I just thought a little low. long story short. I replaced the 12v wire from battery to starter and added a ground wire also. No problems since.
Old Sep 13, 2009 | 06:33 PM
lawlsss's Avatar
the first time it happen i brought a new battery for it already then 2 week later it happen again. and im didn't check the light ill do it when it happne again.
Old Sep 13, 2009 | 08:03 PM
lawlsss's Avatar
anyhelp before i got buy a new starter 2m?
Old Sep 14, 2009 | 08:53 AM
lawlsss's Avatar
Bbump
Old Sep 14, 2009 | 12:54 PM
lawlsss's Avatar
i drove ther car today and it start fine so what the deal here?
Old Sep 14, 2009 | 09:24 PM
lawlsss's Avatar
BUmp
Old Sep 14, 2009 | 10:23 PM
thumper64's Avatar
If it works when you hit the starter, it's probably the starter. Try cleaning terminals and seeing if that helps, but I'll bet it's the starter.
Chris Teodoro
Mar 12, 2016 12:47 PM
DatDCboi
Jul 8, 2011 09:49 PM
EGHondalover88
31
Jan 18, 2010 03:26 PM
SwiftTypeR
Jan 3, 2008 06:46 AM
jorge59la
Sep 16, 2007 06:28 PM
