Gs-R Slave cylinder problem
Old Aug 27, 2002 | 02:30 PM
VtecInteg95's Avatar
Default Gs-R Slave cylinder problem
It seems like the slave cylinder becomes "dry" or short of lubricant after driving the car for about an hour, but is okay after sitting for a while. Does this mean its going bad or can it be lubricated to fix the problem. The signs of this problem are the clutch looses smoothness and becoems more tense, and makes a dry squeeking noise when releasing or engaging the clutch. If anyone knows whats up, help me out. thanks
Kyle
Old Aug 27, 2002 | 04:07 PM
Nameless RB26's Avatar
Default Re: Gs-R Slave cylinder problem (VtecInteg95)
Maybe try bleeding the line a little bit..
I don't know much about that thing. You can probly pick up a new one for really cheap (the line too).. I believe you can use a slave cylinder from a civic too, but not the line. (96-00 as far as I know)
[Modified by Nameless, 1:08 AM 8/28/2002]
Old Aug 27, 2002 | 08:43 PM
wall of tvs's Avatar
Default Re: Gs-R Slave cylinder problem (Nameless)
i've been having the exact same problems....i've replaced both the slave and master cylinders, and the problems keep coming back. i've also tried the good ol' "remove the slave cylinder and grease the ball tip" trick, and that didn't do ****.
hit me up if you know/fix anything....i'm guessing that it's probably the clutch fork.
Old Aug 28, 2002 | 01:37 PM
Default Re: Gs-R Slave cylinder problem (wall of tv's)
same here.. i just did that trick and the problems came back no more than 10 minutes later, i also bled new fluid into the clutch. still no help. Someone here has to know whats goin on, and if you do id appreciate any help i can get, this problem is really bugging me. Thanks
Old Aug 28, 2002 | 01:39 PM
It must be the clutch fork, but that means the trans has to come off to either replace or grease that fork up. Yea that might get expensive for alittle grease. Thanks.
Kyle
Old Aug 28, 2002 | 08:29 PM
i'm probably gonna wait until my oem clutch is shot to drop the tranny -- might as well kill two birds w/one stone
oh yeah, i'm at about 97xxx miles now
Old Aug 29, 2002 | 07:16 PM
Yea its been determined it is the slave cylinder, its all dried up outside and im sure it is inside, im goign to try to grease the outside again and see what it does, otherwise in a few k ill changed the clutch and the slave cylinder, i also have a slight leak from my clutch master cylinder. Nothing major, but ill nock out all the problems at once. I am at 79,000. But plan on a new clutch by spring for my turbo setup.
mmvito
Jan 23, 2008 02:30 AM
lukerc45
Dec 13, 2007 11:42 AM
majinx4
Jun 14, 2006 05:46 AM
B18PoweredCivic
Sep 24, 2003 10:58 AM
