Clutch went out
Clutch went out
So i was going out of town and when i took the wrong exit i made a U turn and after i got going my clutch just goes out. After further inspection i see my clutch slave cylinder dangling leaking fuild, it doesn't move at all. Is this slave cylinder the problem or could it be my release bearing or fork?
Re: Clutch went out (majinx4)
If it's leaking fluid it's most likely the slave cylinder, or the valve in the master cylinder is going out.
Replacing the slave cylinder should fix the problem.
Re: Clutch went out (nota-eg)
Not trying to be an *** or flame you or anything, but don't you think thatif your slave cylinder was leaking you would assume that was the problem? Anyway good luck to you.
tbonez
06-12-2005 05:27 PM
