car dips below idle and almost dies?
Old Sep 13, 2009 | 03:10 PM
Car Tweaker's Avatar
Default car dips below idle and almost dies?
i have a 92 civic with a b18b1(98 ls) in it. After the car is warmed up and im sitting at a traffic light or something and tap the gas the rpms will go up like there suppose to, but when the rpms fall back down to idle the rpms go to low and the car almost dies out.
anyone have any idea what this could be?
thx dan.
Old Sep 13, 2009 | 04:09 PM
skaternak's Avatar
Default Re: car dips below idle and almost dies?
thx dan.
does it idle perfectly fine? adjust the idle screw thats on the throttle back check the cable idle. mine use to do the exact problem adjusted the screw and cable fixed the problem
Old Sep 13, 2009 | 04:12 PM
MHDesigns's Avatar
Is your throttle cable adjusted properly? Maybe tighten it up, see if it helps. it may just have some slack.
Old Sep 13, 2009 | 04:52 PM
ninjaturtleEG's Avatar
maybe time for a tuneup.
Old Sep 13, 2009 | 04:59 PM
92eg_h22's Avatar
Clean out your IACV...two bolts on the front of the IM..unplug the sensor and the rubber hose.
clean it up and reinstall and see what happens
Old Sep 13, 2009 | 05:14 PM
thecruzs2007@yahoo.com's Avatar
that happened to me today at the gas station on my d16z6...i turn the car on and it was idlin a like 500 and it died...i cleaned the IACV and its good now dude..
Old Sep 13, 2009 | 07:09 PM
yea i already cleaned my IACV, if i brought the car for a tune up, what would they do that would stop the idle from dipping down like it does?
Old Sep 13, 2009 | 08:28 PM
im no mechanic but my last car was a pos and had similar problems. fresh plugs, wires, etc. could help. might be fuel related. try replacing fuel filter or it might be something more like fuel pump.
Supp Dude1
10
Sep 17, 2013 12:21 PM
DAJay93
Nov 30, 2007 11:40 PM
emooheo
Mar 23, 2007 02:34 PM
shooitzlinh
Jan 8, 2005 09:52 PM
headhunter
Aug 18, 2003 08:14 PM
