chipped ecu.. no fuel pump...help
Old Sep 12, 2009 | 09:14 PM
no_rice_please's Avatar
Default chipped ecu.. no fuel pump...help
im just wondering what is wrong with my ecu...
its started out like a main relay problem.. sometime the
fuel pump will prime and sometime it wont.. until last
week when the car will not run at all.. the fuel pump will
not prime.. i thought it was the main relay at first so i switch
that with a good relay and still no fuel pump... so i thought maybe
the fuel pump it dead switch that out and same thing..
nothing happen... so i was out of ideas so i call a buddy to bring his
ecu over to try it out and it start on the very first crank.. i also
try my ecu on his car and it did the same thing.. no fuel pump..
so i was just wondering whats wrong with my ecu.. and what do i need
to do to get it working again... thanks ht...
it a chipped p28 on crome for a gsr turbo if that makes any difference..
Old Sep 13, 2009 | 07:09 PM
Default Re: chipped ecu.. no fuel pump...help
no help??>........
Old Sep 13, 2009 | 07:25 PM
mtber's Avatar
It sounds like a component in your ecu may have failed (capacitor) etc...
Replace the ecu.
Old Sep 14, 2009 | 08:35 AM
boosted k20's Avatar
a quick fix will be to take the fuel pump wire from the ecu (Pin A4) cut it and connect the harness side (not the ecu side) to ground. this will make ur fuel pump prime all the time. one of my ecus fried the fuel pump capacitor and i did this and ecu works fine. no problems
Old Oct 12, 2009 | 09:36 PM
musikpal's Avatar
Hi, did u remember what kind of result u got when u check the main relay harness for continuity? I couldn't figure out what's wrong. The current flow is reversed when ECU is connected. U can check my post in the link below(it's kind long).
Thanks in advance
https://honda-tech.com/forums/tech-misc-15/i-need-some-brains-help-probably-wiring-problem-2660937/
beenba
Feb 3, 2018 07:56 AM
jdmAccord210
Engine Management and Tuning
Oct 22, 2013 11:22 AM
Galan
May 21, 2011 03:55 AM
krysted9354
20
Apr 8, 2009 03:32 PM
b16a1sirhb
Apr 9, 2003 11:50 PM
