Grinding
Old Sep 12, 2009 | 08:56 PM
MHDesigns's Avatar
Default Grinding
Motor: ls/v with gsr tranny competition clutch with 8.5 lb flywheel. clutch/flywheel approx 15,000 miles.
Problem: Grinding at thetop of gears, about 7900RPM
I had a short shifter for a while, but changed it back to oem a while ago. Since then I haven't done anything but "grocery get" in it so I don't know if it's just the long shifter or if something else may be wrong. Just took it out to finally go fast and now it is having this problem.
I guess I'm asking people making over 200whp, if they experience grinding issues with a long shifter. I know it's not me because I drive my friends cars and they don't do that like mine. If I still had the short shift I would just swap it out but I don't. I hate tranny problems, and don't know much about them. Thanks for any help.
Old Sep 12, 2009 | 09:13 PM
ballisticej1's Avatar
Default Re: Grinding
I've had 2 tranny's in my turbo single cam, and both of them started grinding at high rpms going into third gear.
Old Sep 12, 2009 | 09:18 PM
MHDesigns's Avatar
Well I've had tranny's that got the notorious 3rd gear grind, but this will grind in second and fourth too so I'm confused.
Old Sep 12, 2009 | 09:24 PM
DCRB's Avatar
you're not low on fluid are you? when was the last time you had your tranny fluid replaced?
Old Sep 12, 2009 | 09:30 PM
MHDesigns's Avatar
It's been flushed within the past couple months. No leaks. Full.
Old Sep 12, 2009 | 11:41 PM
MHDesigns's Avatar
bump
Old Sep 12, 2009 | 11:45 PM
boxeocampeon's Avatar
check the tranny fluid
Old Sep 12, 2009 | 11:48 PM
MHDesigns's Avatar
fluid is fine...again
supersilverdc2
Nov 30, 2013 06:46 PM
SLPRcivic
Mar 14, 2006 06:42 AM
one^g
Jan 4, 2006 01:03 PM
turbo gsr
Oct 2, 2005 06:37 PM
RudeLude95
Aug 17, 2005 07:18 AM
