D15B7 mini-me swap running rich
Old Sep 12, 2009 | 02:08 PM
Makikun's Avatar
New User
Default D15B7 mini-me swap running rich
I've completed a mini-me swap and I'm running into some issues. First, its a D15B7 block with a Z6 head and P28 ECU. Lately it has been running rich and burning a decent amount of oil. When I was in the process of changing the head, I did not notice that much buildup on the pistons so I'm not sure if it is the rings... Also, when I accelerate past 3,500-4,000RPMs, the smoke just pours out of the exhaust. I'm not sure where to start. I'm using the injectors and fuel rail from the B7 head so I was thinking about changing out those first. Any ideas? And yes I know I should just go B series lol but I can't afford it ATM.
Old Sep 12, 2009 | 02:43 PM
Former User's Avatar
Default Re: D15B7 mini-me swap running rich
Is your mechanical timing off by one tooth on the timing belt?
If the mechanical timing is fine, have you checked the ignition with a timing gun? Any CEL codes?
Old Sep 12, 2009 | 03:45 PM
Makikun's Avatar
New User
Checked the timing, looks good. I am not throwing a CEL. Did not check ignition as I do not have a gun...
Old Sep 12, 2009 | 03:49 PM
Your local auto parts store may offer a free rental on a timing gun.
Old Sep 12, 2009 | 04:47 PM
Autointeg's Avatar
let me know if you find ur prob, i'm in the same situation, but im running a chipped ob1 gsr ecu(had it laying around) lags on 2nd gear
hastingsr
Aug 22, 2009 12:37 PM
j0keefe21
10
Mar 28, 2009 05:59 PM
Jet Black
Nov 25, 2006 06:49 PM
jdmeg95hatch
Jun 4, 2004 05:09 AM
Mantis88ls
May 14, 2004 05:37 AM
