changing D16Y8 O2 sensors?
Old Sep 12, 2009 | 11:41 AM
FlewByU352's Avatar
Default changing D16Y8 O2 sensors?
I got the heat shield off the header and moved out of the way but I have no idea how to get the sensor out. The biggest wrench I have is 19mm and its bigger than that, also the angle it's at the wrench has a hard time fitting because of all the AC components. I would try a socket but the connector and wires are in the way. How the heck do I remove it? I sure hope the one in the cat is easier to remove.
Old Sep 12, 2009 | 11:49 AM
Former User's Avatar
Default Re: changing D16Y8 O2 sensors?
Some PB blaster and a breaker bar will help. Go to your local auto parts store and buy a special O2 sensor socket like this one:
Old Sep 12, 2009 | 11:58 AM
FlewByU352's Avatar
ahh gotcha, yah i've been spraying the PB blaster and I got a wrench to turn it a little bit but its not close. I wonder if I can rent it from autozone.
Old Sep 12, 2009 | 12:00 PM
Originally Posted by FlewByU352
...and I got a wrench to turn it a little bit but its not close. I wonder if I can rent it from autozone.
A breaker bar will give you more torque. Definitely ask AutoZone about a rental because the socket costs $10-$15 to buy.
Old Sep 12, 2009 | 01:05 PM
xXB18EKHatchXx's Avatar
Advanced Auto sells them for about $10 and they have them for rent also.
Old Sep 12, 2009 | 01:44 PM
FlewByU352's Avatar
I got the one in the header out which is the primary I believe. I tried a quick cleaning with a wire brush and cleaner. Dried it and put it back in, reset the ECU and the CEL came back on. Kinda figured that would be the case. How can I tell which sensor is bad? I doubt my "cleaning" actually cleaned it to work if that was the one that was bad. Also are the sensors the same for all Honda OBD2 motors? Reason I ask is I am looking to swap a B18c type R in and thats OBD2. I would hate to have bought new ones for the D16 when it isnt staying in and then they cant be used for the new motor.
Old Sep 12, 2009 | 01:52 PM
The CEL codes are different for the primary versus secondary O2 sensors. What CEL codes are being thrown?
Old Sep 12, 2009 | 02:04 PM
FlewByU352's Avatar
Thats what I figured because I thought the primary is for the A/F ratio and the secondary is just a cat efficiency or something. I wish I had my own scanner or w/e, Autozone just told me its my O2 sensors and I asked which one and they said you should replace them both. I'll have to go back and get a different guy to do it.
Old Sep 12, 2009 | 02:27 PM
You don't need a scanner. Reconnect all sensors, clear the codes from the ECU, run the engine, and then pull the codes at home as described here.
Old Sep 12, 2009 | 03:27 PM
FlewByU352's Avatar
wow amazing, 1 flash and i assume its the short 1. so the 1st or primary oxygen sensor is bad. that is quite the trick
Old Sep 12, 2009 | 03:31 PM
So now you can focus entirely on the O2 sensor before the cat.
hydengr
Honda Civic (2001 - 2005)
May 27, 2015 10:02 AM
TonyRomo
Mar 8, 2011 11:42 AM
ludermark
Oct 27, 2004 05:46 PM
simplypinoyy
14
Jul 26, 2004 07:50 PM
StyleTEG
Jul 5, 2002 10:28 PM
