I Need Help!!! Map Sensor Problem!!!
Old Sep 11, 2009 | 07:20 PM
JDMSOHCEG's Avatar
Icon6 I Need Help!!! Map Sensor Problem!!!
I just recently bought a 92 EG CX. It has a D15b7. The check engine light was on so I checked it and it was the map sensor. Pop the hood, no map sensor or wires!!! What do I do now? Any ideas?
Old Sep 11, 2009 | 07:26 PM
nicefighter80's Avatar
Default Re: I Need Help!!! Map Sensor Problem!!!
what code was it throwing?
Old Sep 11, 2009 | 07:27 PM
shawn_crx's Avatar
Can't remember but 92's and 93+ are difference.
I don't remember which way, but one yr the map is on the firewall and the other is on the TB.
Old Sep 11, 2009 | 07:34 PM
^^^^ yea i was thinking the same, look at the firewall to the right of your TB
Old Sep 11, 2009 | 07:37 PM
JDMSOHCEG's Avatar
It's throwing a code 3. Yeah its not there at all! I have looked everywhere on the firewall and on the TB.
Old Sep 11, 2009 | 07:39 PM
has the code been there or did it recently start thowing the code?
Old Sep 11, 2009 | 07:41 PM
JDMSOHCEG's Avatar
The code was on when I got it.
Old Sep 11, 2009 | 07:50 PM
is there just a random spot on the top of your TB where the map goes?
Old Sep 11, 2009 | 07:59 PM
JDMSOHCEG's Avatar
No, there is a place where it looks like a mount should be on the firewall for it. There are no scew or bolt holes on top of the TB.
Old Sep 11, 2009 | 08:08 PM
1FDUPCIVIC's Avatar
Sounds like you are going to need to do some wire loom searching. You are going to be looking for three wires: a White wire that will go to terminal #1 on your map sensor, a green-blue or green-white (could be either, sorry) this wire will go to terminal # 2, and yellow-green or yellow-red (again could be either) this wire will go to terminal # 3. All of these wires will come from connector D on your pcm, terminals 17, 21, & 19, respectively. Once you have the wires you will want to buy a map sensor and plug it in, you know, homemade style! grab a vacuum line and hook it up to manifold vacuum and grab a zip tie and secure that baby! Bam! you got a map sensor! Good luck buddy
Old Sep 11, 2009 | 10:43 PM
JDMSOHCEG's Avatar
Thanks alot man I will try it for sure!!!
mr2turbo007
Apr 23, 2012 06:22 PM
FSS13foxtrot
Jan 20, 2008 06:23 AM
vtec25
Oct 6, 2004 08:26 PM
MugenizedR
Nov 1, 2003 03:43 PM
