Code 3 map sensor broken?????????
Old Oct 30, 2003 | 03:23 PM
MugenizedR's Avatar
Default Code 3 map sensor broken?????????
I got a cel today and its a code 3 map sensor. It's plugged in.... anything else I should check for?
I had this problem before and the dealer found a broken electrical connecter.
Where is this? I unplugged the map sensor plug and everything is connected.
Modified by MugenizedR at 5:16 PM 10/30/2003
Old Oct 30, 2003 | 04:55 PM
Dan GSR's Avatar
Default Re: Code 3 map sensor broken????????? (MugenizedR)
also try cleaning out ur throttle body / intake manifold
probably wouldn't hurt to hit the map with t body cleaner
Old Nov 1, 2003 | 03:34 PM
MugenizedR's Avatar
Default Re: Code 3 map sensor broken????????? (Dan GSR)
The throttle body is clean. Anyone else?
Old Nov 1, 2003 | 03:41 PM
twuelfing's Avatar
whats the actual code your getting?
P0107?
measure the voltage from the #3 pin and the number 1 pin on the MAP connector
measure the voltage from the #3 pin and the number 2 pin on the MAP connector
the number 1 pin is the one nearest the notch in the connector.
should get about 5 volts on both of not you have a broken wire between the ECM and the MAP sensor.
Modified by twuelfing at 1:05 AM 11/2/2003
Old Nov 1, 2003 | 03:43 PM
MugenizedR's Avatar
Default Re: Code 3 map sensor broken????????? (twuelfing)
Code 3, does anyone know how to remove the three wires that go into the map sensor's plug?
92ehatch
16
Feb 19, 2007 11:41 PM
vtec25
Oct 6, 2004 08:26 PM
IVI
Aug 26, 2004 01:04 PM
Tw1n Turb0 Z
Jan 15, 2004 11:48 PM
