Extreme Engine/Transmission Lag in B16A
Ok, first off, I have a 92 Civic with JDM B16, has about 800 Miles on the swap and 40K Miles Total.
I was driving down the road, just cruising like normal when I turn onto the road where I like to open up my Civic. Car was running fine, like usuall. I down shift into 2nd and hammer it, however, it felt like someone was pulling on the car from behind till VTEC kicked in and it luanched. I pulled over, put it in 1st, and gunned it. From take off till VTEC kicked it, it felt like someone was pulled the car from behind, or like the brakes where engaged. It had no acceleration what so ever, almost felt like LIMP MODE, but I knew it wasn't due to VTEC kicking in.
I got home, popped the hood. Smelt a burning smell that I am not familiar with, no oil or gas. No codes besides the Code 14 I've had since swap, IACV. Started it back up, went down the road, and it seemed like it was accelerating even slower.
I have no idea what could be going wrong, any advice would be appreciated.
Check the timing, chase down the fuel lines, check the ecu, sparks plug/wires/Distributor, and last but not least hope that the valves aren't bent!
CanoTech88
21
May 2, 2012 04:32 PM
miece16
Jun 10, 2009 02:34 PM
xkhalil333x
Apr 25, 2009 08:17 AM
