What preassure of a new fuel pump should i get to run a wet Nitrous Oxide System?
Old Aug 27, 2002 | 11:51 AM
Foulker's Avatar
Default What preassure of a new fuel pump should i get to run a wet Nitrous Oxide System?
I have just put my new N.O.S system in, a direct port wet system, i went for test runs lastnight, Problem.... i have it set up to a full throttle switch, but when i floor it, it starts to kick in but puts out, when i took the spark plugs out the indication was that it was running too lean, (white residue) so my thinking is that when the N.O.S kicks in it is tacking all the fuel from the injectors, so my question is which would be the best new poundage to run for this kit, thank you for your time....
Old Aug 27, 2002 | 12:11 PM
H23 Power's Avatar
Default Re: What preassure of a new fuel pump should i get to run a wet Nitrous Oxide System? (Foulker)
isn't the lowest shot for the direct port an 80 shot????????
you should NOT run that on stock fuel pump...
what plugs are you running? did you retard the timing?
Old Aug 27, 2002 | 12:19 PM
Foulker's Avatar
Default Re: What preassure of a new fuel pump should i get to run a wet Nitrous Oxide System? (F23 Power)
yes you are correct the smallest is an 80, but i am running bosh platnum 4 plugs, so the plugs are correct, and yes it is retarded, but i know it has to be the fuel, but i was wondering what would be the best pump to use....
Old Aug 27, 2002 | 12:23 PM
H23 Power's Avatar
those plugs aren't good for nitrous...get some zex plugs
get a walbro pump...i would get the low pressure 255 for your app...
http://www.autoperformanceengineering.com/
PowerSpeed Motorsports
Jun 12, 2006 06:05 AM
DirectPortEF
May 18, 2006 05:51 AM
1INTEGRA
Feb 23, 2004 01:21 PM
J337_UNIT
May 29, 2003 10:29 PM
Toretto
Jan 9, 2002 09:33 PM
