car bogs when i accel. then when i flr it pwr comes back
Old Sep 8, 2009 | 09:36 PM
the_dxB16's Avatar
Default car bogs when i accel. then when i flr it pwr comes back
I have b16 93 civic p28 ecu. Seems to happen when warmed up fully. i try to cruise it then it bogs and when i accel. it bogs. But when i floor it power comes back. seems like it bogs from 3000-6000ish rpm. i do have bad spark plug wires and the dizzy rotor rattles sometimes. also my vtec does not work idk if that relates. my radiator cap is kinda messed up. im missing a hose from the pcv box to the intake manifold. only code thrown is 08 TDC sensor. i need help.
Old Sep 8, 2009 | 09:55 PM
driftpasucks's Avatar
Default Re: car bogs when i accel. then when i flr it pwr comes back
i would open your distributer and check it out. the screw for the rotor might be missing. then fix your wires. basic tune up stuff
Old Sep 8, 2009 | 10:35 PM
boxeocampeon's Avatar
change your plugs wires rotor and cap if its not that then its probably your ignition coil. you have a CEL?
Old Sep 8, 2009 | 10:46 PM
the_dxB16's Avatar
alright, cool i only the cel 8 TDC sensor.
bitts teg
Nov 23, 2010 05:28 AM
djviet2000
Aug 3, 2010 02:03 AM
Frost7177
15
Mar 6, 2009 04:18 PM
MISFITofMAGIC
Jan 23, 2007 08:13 PM
gsrboi80
Jul 1, 2005 01:33 AM
