help on b16a to Ek
Old Sep 8, 2009 | 08:58 PM
oneEg1Tc's Avatar
Default help on b16a to Ek
Ok. So. I just got a 97 ek and. I have a b16a sitting there. And. Was wondering. What's the things. I. Need to this swap but that I mean what type. Of harness and. Distributor. And so thanks. ..
Old Sep 8, 2009 | 11:03 PM
sii.'s Avatar
Default Re: help on b16a to Ek
SEARCH.
Old Sep 9, 2009 | 07:18 AM
jdmcivicracer89's Avatar
Originally Posted by sii.
SEARCH.
first actually try searching. its been beat to death about this.. its a very easy swap and ull need the 99-00 harnass ecu mounts and axles
Old Sep 9, 2009 | 08:14 AM
LovesOrangeSoda's Avatar
can use your same harness with plug mods
Old Sep 9, 2009 | 10:17 AM
oneEg1Tc's Avatar
I had that. B16a. On my. Previous Eg. And. I. Had cables. Here. And there. But. I don't wannago thru the same. Thing . So will. A. Si harness do the trick. ?
Old Sep 9, 2009 | 12:08 PM
geneeunit's Avatar
yes, and no.. since you have a 97, its OBD2a.. 99-00 si's are OBD2b. wiring is a little different, so you would have to swap the underdash harness as well.
just get a 96-98 EX harness, with a obd2a -> 2b conversion harness and run the p2t ooorrrr.. obd2a to obd1 and run a chipped ecu.
Old Sep 9, 2009 | 12:56 PM
D3vin's Avatar
Are you sure you want to put a motor older than your car in it? B16a are from the 90s CR-X if I'm correct.
Old Sep 9, 2009 | 03:47 PM
oneEg1Tc's Avatar
i guss it one of my options , i mean the ek has a zc engine rusti and old it the b i got it for a god price .. i dunno what else to put in there having in mind im working on it on a budget
Old Sep 10, 2009 | 09:38 AM
skaternak's Avatar
ek? so you have a rhd?
JPerkMr954
Feb 22, 2011 07:19 AM
threehonda
Jul 28, 2010 04:42 AM
threehonda
Jul 26, 2010 10:33 AM
ekpilot
Aug 2, 2006 09:38 PM
xkagax
Sep 18, 2005 09:56 PM
