EM1 idling weird
Old Sep 8, 2009 | 06:23 PM
donovan772's Avatar
Default EM1 idling weird
Just had my car worked on about a week ago and since then it's been idling lower than usual, 1000 to 1500 range sometimes lower. Could it be a timing issue?
Old Sep 8, 2009 | 07:07 PM
green99civic's Avatar
Default Re: EM1 idling weird
You could retard the timing a little buy turning you dizzy back a little to see if that would help with your issue.
But yes could very well be a timing problem.
Old Sep 8, 2009 | 07:09 PM
FaTBoY707's Avatar
well if 1000 to 1500 is low to you .. then what did your car idle at before? cuase mine idles a bit below 1000 all the time
Old Sep 8, 2009 | 07:13 PM
It could also depend on what climate you are in execially if its your daily driver or not.
Old Sep 8, 2009 | 08:41 PM
vndsd1's Avatar
it got problems if ur car idle at 1500, suppose to be under 1000
Old Sep 9, 2009 | 03:20 AM
donovan772's Avatar
It gets so low it'll just shut off sometimes, and my check emgine light is on.
Old Sep 9, 2009 | 05:39 AM
Jimster480's Avatar
Jump the Service connector and pull the codes. it could be IACV.
Old Sep 9, 2009 | 07:17 AM
migrod1's Avatar
EM1 idle at 700 rpm stock
Old Sep 9, 2009 | 12:47 PM
donovan772's Avatar
Okay so if they idle that low then whats my problem? my check engine light is on, my intake filter is dirty could that be it, if so i read that you can use a shop vac to clean them out, is this true?
Old Sep 9, 2009 | 03:29 PM
Jimster480's Avatar
Just get a Short ram or a K&N Drop in.
Old Sep 9, 2009 | 03:39 PM
FaTBoY707's Avatar
well if your air filter is dirty you should clean it anyway.. but i agree with jimster.. find what code its throwing
Old Sep 9, 2009 | 06:09 PM
donovan772's Avatar
I cleaned mine earlier but its still dirty, its a injen short ram. Could it be causing the check engine light to come on?
nekoabandoned
Feb 16, 2009 10:13 AM
bizzarizzo
Nov 9, 2007 09:50 AM
NoVALude
Nov 20, 2006 11:02 AM
stoopid_monkey
Apr 26, 2005 11:22 PM
1hotcivicSi
Mar 16, 2004 02:01 PM
