Transmission & Drivetrain Gearboxes, Differentials, Clutches
Cable Diff in a Hydraulic Trans.
Old Sep 7, 2009 | 06:01 AM
slopoke1989's Avatar
Default Cable Diff in a Hydraulic Trans.
I have an EK that I dropped the engine and transmission from my CRX into. I am sick of the feeling of the HASport clutch conversion kit. I have an OBX LSD in my cable trans and was hoping to transfer it over to a newer GSR trans. Has anyone done this? I would just assume I need to change the ring gear and run my Cable Trans Axels. let me know. Thanks guys!
Old Sep 8, 2009 | 06:07 PM
Default Re: Cable Diff in a Hydraulic Trans.
Anybody?
Old Sep 9, 2009 | 04:54 PM
Just lookin for a bit of help
Old Sep 9, 2009 | 07:16 PM
SkunkedRex's Avatar
i put a hyjro OBX diff in my cable Ys1 an used Cable axles "there all the same".. Everything went great.. Just one thing you need to look for, Is the lash on the Diff. The cable trans dont have shim's but the Hyjro does. I didnt use anything for the Hyjro in mine but for the Cable diff in the Hyjro. i think you should use the shims for that tran's.
If everything looks good put it together.. The worst can happen is just a little wineing noise like a straight cut gear race tranmission.. \
It worked for me everything was fine
Old Sep 10, 2009 | 01:40 PM
Thanks for the help man! I'll just tear it up and set it up! I'll keep ya posted.
alldayda9
Nov 14, 2011 07:50 AM
Disco
May 24, 2011 06:12 PM
BlownHatch
Jul 20, 2006 05:29 AM
sikciv666
Jan 31, 2006 12:32 PM
