e-brake light comes on when i stomp on it
Old Sep 6, 2009 | 03:15 AM
lunch_box_4_life's Avatar
Default e-brake light comes on when i stomp on it
every time i accelerate hard the e-brake light comes on
when i let off it goes out
i have even unplugged the e-brake switch wire and it still does it
is this anything to worry about
any idea
i drive a 98 civic dx
stock motor stock computer
full cold air
full exhaust
thanks in advance
Old Sep 6, 2009 | 03:31 AM
shytdoode's Avatar
Default Re: e-brake light comes on when i stomp on it
probally break master cylinders a little low of fluid check it out and top it off as needed
Old Sep 6, 2009 | 03:55 AM
BryanM.'s Avatar
Resident Gearhead
That is most likely the cause. Check out the reservoir, I bet it needs to be toped off.
That light not only indicates that the E brake is engaged, but also low fluid in the reservoir. When the fluid level drops, the float in the reservoir causes the E brake light to turn on.
Old Sep 6, 2009 | 05:23 AM
batallic's Avatar
thank u helped me too, i had the same problem last nite
Old Sep 6, 2009 | 05:52 AM
GYChris's Avatar
x2
Old Sep 6, 2009 | 06:01 AM
NACvicSi's Avatar
Na you just hit vtak, it's a built in shift light
Old Sep 6, 2009 | 06:37 AM
Former User's Avatar
Low fluid in the MC reservoir would generally indicate worn brake pads or a leak. Check for both.
Old Sep 6, 2009 | 09:19 AM
eskimo10's Avatar
So when my e-brake light is on even after I release the break, its more than likely due to low fluid in the reservoir? Mine often times will stay on for a while, and then go off, but maybe not for like a half hour, and maybe only for like 5 minutes.
Old Sep 6, 2009 | 09:23 AM
Check the fluid level in the reservoir.
Old Sep 6, 2009 | 09:27 AM
eskimo10's Avatar
Ok sounds good, will do. I was thinking the switch was going bad, but this makes more sense.
Old Sep 6, 2009 | 09:54 AM
ChillinTheMost's Avatar
good question my car was doin the same thing but now its on and doesnt turn off. thanks for the answers
Old Sep 6, 2009 | 05:24 PM
that's what it was thanks guy never would have thought of that
Old Sep 6, 2009 | 06:49 PM
HackeN's Avatar
in my old ef hatch when i stomped it the ebrake light & hatch light would come on. it always gave us a good laugh.
EFz6er
Jan 21, 2009 10:41 AM
JDMmovement
Apr 26, 2008 08:50 PM
91H4hatch
Feb 17, 2007 07:15 AM
SwampThing
Jan 11, 2005 03:30 PM
mugen89
Aug 8, 2002 10:13 PM
