need help on my civic
guru's I have a 95 civic (stock engine,auto trans) 165thou miles. Problem is everytime I drive the car in a highway specialy a little bit up hill, as soon as I exit the freeway the first stop light my temp. guage start to go up,when I open the hood I can see a boiling coolant in the reserve tank. The thermostat is new,the radiator fan is working every 70 sec. and it will run for 8 sec. The weird thing is if I drive it in a regular street with a/c no matter how long it doesn't overheat also in a freeway with traffic I drive it with the a/c on no problem but as soon I get off the exit it start to overheat.
things that I've noticed to my car.
1. radiator fan start to kick in every 70 sec. and it will run for on 8 sec.
2 white smoke coming from the engine oil dip stick.
3. I can smeel the antifreeze when it overheats.
pls. I need help.
additional info:I tried to tap the wire for the rad fan switch so it will always be on everytime I use the car but still overheats as soon as I exit the highway and my reserve tank is still boiling eventhoug the fan is always on.
pls. I need help.
it couldn't hurt if you have a air pocket in the coolant it will mess with alot of things use the search button there is a million threads on people having problems like this but i would try this first
civikpowa
Honda Civic (2001 - 2005)
Apr 10, 2010 05:06 AM
HondaGuy951
20
Aug 1, 2009 04:28 AM
PureEF8
Jan 20, 2006 06:28 PM
