1997 Civic LX Overheating??.........Need Clarity
Hey guys, I'm having a bit of an overheating problem. my hoses/radiator/coolant level and what not are fine. what the car does is, it will start to get hot after a while of driving when i'm at a stop light or something (idle) but when i get moving, it returns to normal. is this my thermostat? I just picked one up so I was just making sure. anyone got a detailed write-up on changing the t-stat and bleeding the system and what not?! any help appreciated! thanks guys!
P.S. Motor is D16y7. Car is 1997 Civic LX AUTO Tranny. Motor is Stock except for CAI.
Re: 1997 Civic LX Overheating??.........Need Clarity
Sounds like the radiator fan doesn't turn ON when the engine gets hot. Try jumping the 2P connector for the fan switch on thermostat housing. It should then run continuously and prevent the overheating. If so, replace the thermoswitch.
This is a common problem that is typically but not always caused by a bad thermoswitch. If the fan does not run continuously after jumping the 2P thermoswitch connector with the key in ON(II), then run wires directly from the battery to the fan. If the fan doesn't run, the fan motor is bad. If it runs, check the fan relay under the hood and continuity of the wires.
Also try bleeding the cooling system:
Park the car on an inclined driveway with the front higher than the rear and turn the heater ****/lever to MAX heat.
Then follow steps 9-12 precisely:
Open the cap of the radiator, turn on the car, watch the water, put your finger in the water, wait for it to "warm up" It wont take too long if everything is working correctly. If water is flowing and warming, replace the radiator. Being the stock junk that came with the car it had a tiny crack in the plastic which expanded when hot and the car would overheat when idling. Replaced the radiator, never gets half way now... no matter what.
It takes 5 minutes, and 80 dollars for a 1" rad off ebay .. too easy.
u got a mechanic, send it to the H institute where a arab and a white guy will be more than happy to work on ur car lol, i got a thermostat for u if u need it, and actually i got a brand new D series water pump too in box lemme know
acurajeff
06-27-2010 12:42 PM
spidermancivic
05-05-2009 09:07 PM
