hard to go into second gear?
Old Sep 3, 2009 | 11:50 PM
sii.'s Avatar
Default hard to go into second gear?
94 si. og motor/tranny. 2nd gear is harder than the rest to go in. doesnt pop out or anything. like i cant slam it in. regular driving is kinda hard too. but not impossible. clutch?
Old Sep 3, 2009 | 11:52 PM
MHDesigns's Avatar
Default Re: hard to go into second gear?
Does it grind if you try to slam it in? like if your driving fast or at high rev's?
Old Sep 3, 2009 | 11:59 PM
sii.'s Avatar
no grinds.
Old Sep 4, 2009 | 12:01 AM
MHDesigns's Avatar
Odd. If there were I would say synchros,... Have you checked the condition of your shifter bushings? they could just be worn, or falling apart. Other than that I don't know. Good luck.
Old Sep 4, 2009 | 12:03 AM
sii.'s Avatar
ill check tommorow, i do need to tighten my shifter a lil too. thanks MH.
Old Sep 4, 2009 | 12:07 AM
Grevved's Avatar
I would say either your shifter, or just 2nd is pooping out.
Had a somewhat similar problem like that in my old hatch, only it was 1st gear, ended up being the synchros. Then the tranny finally had enough of it and put a big *** crack on the bottem of the tranny.
Good luck
Old Sep 4, 2009 | 12:10 AM
MHDesigns's Avatar
Someone makes a urethane set. I have a set in my car and I personally love them. They're a little stiff so it takes a bit of play out of your shifter but is still very smooth. If yours are bad they're worth a shot. only like 12 bux.
Old Sep 4, 2009 | 10:05 AM
sii.'s Avatar
ttttttttttt
Old Sep 4, 2009 | 10:15 AM
boxeocampeon's Avatar
you guys dont think its the tranny starting to go out?
miamiboy91
Apr 16, 2009 04:26 AM
knight_kidD
Jan 5, 2008 10:45 PM
msmotorsports
Oct 17, 2005 05:45 AM
cr-x si
Jun 11, 2003 09:06 PM
